Clock trademark help
Stuart2
This mark is attributed to a company called "Gerbr Rechiel" in the town of "Markt Dietenhofen, Germany"
thought to appear also on some "Germania Regulator Factory" clocks so probably taken over by that company at some point.
There is no information other than trademark origin that I can find.
3 hours ago, oldhippy said:
Thanks wls1971, I couldn't find a thing about the makers mark.
I use a number of books by Karl Kochmann, his best known is "Clock and Watch Trademark Index of European Origin" well worth seeking out his books for anything German he was meticulous in his research of German factories and makers.
3 hours ago, Stuart2 said:
unfortunately the clock had worm so i took it apart and treated it
German Vienna clocks seem very susceptible to worm it's the soft wood, I bought one sight unseen at auction once it was absolutely riddled with worm, I now use Rentokill wax polish once a year on my wooden clocks.
  • 4 months later...
I've got four Vienna's on my wall I have to hang them so far up the wall I need a step ladder to wind them, I have a cat that see's every thing I hang on the wall as a challenge that must be met, thankfully she not a scratcher, just has an eternal quest to reach the highest point in any room.
16 minutes ago, watchweasol said:
The curtains are not safe then? and best not keep a Budgie.
11 minutes ago, Stuart2 said:
I bet she loves cuckoo chains
Her favourite spot is on top of the bookcases in the living room the route is across the top of all the clocks on the mantle piece, jump onto a grandmother clock and then onto the book case her route down is much more direct straight onto the sofa from height which is not so good if I doze off on it.
The case looks much better the colours evened up nicely what did you use have you just waxed it ?
It was originally treated for woodworm, then thoroughly cleaned then i used liberon medium oak black bison wax and plenty of elbow grease. The movement was really well made, dead beat escapement with maintaining power, just required new lines and a strip down and clean and probably one of the only clocks that i have done like this that did not require any bushings. Really pleased.
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it.
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
