Platax Tool On The "bay"
Marc
Anyone after a Platax tool on the cheap I think I may have spotted one that is incorrectly described on eBay.
Item #381172516478
It is listed as an MKS standard staking set which is only half right. The box is from an MKS standard staking set as are some of the stakes and stumps, however, sat in the middle of the box is what looks to me like a Platax.
I don't know how complete it is but MKS sets usually go fairly cheap in comparison to Platax tools so could be a real bargain for someone.
It don't look like a Platax, it is a Platax. You can see better in the last picture. A little tatty but... The problem is, this kind of auction (staking tool set) generally ends with final price up to GBP120. And without Platax. I wonder how high this item will end.
How bizarre. The platax tool is lumped into the staking box. It will be interesting to see what this goes for - a very good platax, boxed, went for £240 recently. I suspect this could go to £150.
I find that bargains are getting very rare these days on eBay with more and more people using sniping software.
Slightly off topic but I recently smiled to myself when an incabloc stump set went for slightly more than cousins actually sell them for brand new!
Unfortunately the Platex is longer available new.  I don,t know if Bergeon no longer manufacture them (from Cousins anyway) so eBay is the only way to get one.  Why the halt in production of these tools is strange with no equivalent being produced.
The eBay final prices of tools are often more than new as Mark points out.
Edited by clockboy
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
