Here's some information on the output of the Cousins LED light as measured by a lux app on my IPhone.
This light is fitted with two rows of LEDs that can be both individually selected and dimmed. The readings were taken with my phone 10" below the light as this is the height I have it when working on watches. I also measured the light colour temperature at the different settings.
One row low setting 1,240 Lux ......... 6600K colour.
Two rows low setting 3,960 Lux ......... 6000K colour.
One row high setting 5,450 Lux ......... 6300k colour
Two rows high setting 20,800 Lux ....... 5600K colour
To give an idea of how it compares with the Cousins small portable fluorescent desktop lamp that I have currently been using.
At the same distance of 10" it gave 3,170 Lux .......5600K colour
At a distance of 5" it gave 30,600 Lux ....... 5600K colour although there was a bright hot spot with rapid fall off at the side. This was the the distance I have been using, and it was a nuisance as it often got in my way.
This has been the best improvement I have made regarding equipment this year. Please remember that these tests are for guidance only as I have not used specialised equipment. I hope you find the information useful.
Here's some information on recommended lighting.
Well cousins conveniently removed the branding from the box. (Just a thought: Did someone find it cheaper online and call them out?)
But here is a pic of the tag on the lamp itself.
Hope this helps
Thanks, Mark. Based on the model number,  I found them for sale in Russia and Poland. Strangely not in China. Prices (ex-delivery) approx. £56.2 in Russia and £53.8 in Poland. If anybody interested, I can try to find cost of postage.
Isn't Internet wonderful thing?
Following Rob's link to the model I note that the manufacturer offers samples - see on right under model name. If any of you has a legit company then this might be a way to collar a few lights at a competitive price. You could sign a few of us up maybe? :-)
It is a broad strip-light giving fore and aft shadows. I see them in your photo George, admittedly fairly faint. Is it not better to have a circular light source? Mine is a neon tube but surely it must exist now with LEDs? But if not, then this one is the nbt..
Hi Colin, without having a circular light to compare it with I can't really make comment. All I can say that working on movements has been a lot easier since I installed it. I'm sure others will pitch in when they start using them.
Would you not have to look through the centre of the light as a camera would with a ring flash fitted, to get the result you are after?
I really don't think you would be disappointed with the linear light fitting Colin.
This light is 50 cm diameter and would be placed slightly above head height so as to be able to work underneath. Then there is the problem of shadows from the hands, but on account of the distributed light source these would be less obtrusive than from any other more localised source.
Yes, George, I am sure that the Cousins light is the best at present on the market for fitting to the bench and I shall buy one for my lathe workshop bench that now has a miserable expensive LED spotlight sold for professional machine use, but very heavy on shadows.
Maybe I shall give the circular one a go for my watch tinkering table, although for this, during the daytime, I have hard-to-beat overhead daylight from a roof Velux - except after snow, and we have had plenty this Winter!
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
    • Aloha and thanks for catching all these small but important details, John.  I'm going to give it a shot. The good news is I have a parts movement here with a perfect complete balance.  I will place them side by side for visual reference when doing what you outlined.  It's been a while were I've had a hobby in which I joined a forum.  I forgot just how helpful everyone can be. Mahalo. Frank.
