What is differences between bergeon oilers?
HonestRepair
Hi, I'm using bergeon oiler 30102 for lubricating. I feel it couldn't grip very tiny drop of moebius 9415 for pallet jewels.
So, I searching alternative oiler for it, and found 2 more bergeon made oilers.
These are the Bergeon 5423 and 7013. There is not detail description about them.
Please tell me about what is differences and what is best choice for my problem.
Thank you!
I'm attaching PDFs of each of the numbers you have. But there is a minor problem with the number in that each number refers to a whole bunch a Oilers of different sizes.
Then I'm attaching an image of the 7013 which comes in several sizes. his is listed as their precision oiler because the shape is very defined and will supposedly only pick up a very exacting quantity of oil.
While the problems with looking at the various Oilers and I have a link that shows that is there also made by a variety of other companies. Then the shape at the end can be different. Personally I find I like the flat end of verses the multi-sited ends that some of them have. I don't even know who makes my favorite oiler other than it just says made in Switzerland I know what I found a style I liked I purchased several of them so I wouldn't have to worry about it.
Then conveniently am not finding it but I've seen articles out there of people that will modify the oiler themselves. Another result flattened them's the more flat bill conceivably shapes them and the sums shape that they like or they perceive is somehow better. So if you don't like one try purchasing something else.
https://www.esslinger.com/bergeon-30102-watch-dip-oilers-individual/
7016 C oiler.pdf 5423 oiler 7017 7018 7019 7020.pdf 30102 oiler 7016 M N O.pdf
7 hours ago, clockboy said:
  • I have been using the Bergeon oiler you are using for a number of years with no issues apart from (I don’t know how) I damaged the tip of my finest once. The angle you approach with the oiler tip gives various amounts.
I know that the angle and speed of pull out an oiler from oil is critical factor for how much oil get. But, from a while ago, I felt it was little bit difficult to control it. The oiler gripped very much or nothing ?
It was very stressful. Maybe I need more plactice and training, but I want to know what is different more expensive oiler.
7016 C oiler.pdf 747.56 kB · 4 downloads 5423 oiler 7017 7018 7019 7020.pdf 2.71 MB · 2 downloads 30102 oiler 7016 M N O.pdf 2.35 MB · 2 downloads
Thanks for your stuff! Maybe your Switzerland oiler is Horotec or AF.
The 7013 have pipe niddle shape like as little bit modified syringe's. And 5423 and 30102 have same flat tip like spoon. If so, can I understand 7013 give more accuracy quantity of oil by its shape?
3 hours ago, VWatchie said:
I use Bergeon’s “ergonomic oilers” most of the time and always when oiling pallet stones. Silly expensive, as most Bergeon tools, but still worth their price.
Thanks! Is the ergonomic oilers mean bergeon 7013 it have color rings its body?
You started lubricating with it? Or have you ever use flat type oiler? Can you share your expirence more detail? Thank you!
Edited by HonestRepair
May seem daft but have you tried giving your oilers a thorough clean.  if they have been in contact with anything containing silicone oil (seal grease etc), PTFE (some oils), or moly/graphite etc, then these tend to 'plate' onto the oiler and prevent proper oil stiction. May have to be mechanically cleaned (ie with cloth or very fine paper) then finished in an U/S cleaner.
Edited by canthus
OK! Thanks. I will try it!
Yes, they have colour rings. Here's a link to them.
No, I started with normal oilers. This A*F set show in the picture here (no longer for sale it seems).
I found it extremely difficult to oil jewel holes with any precision, not to mention pallet stones, using ordinary oilers and an eye glass. So, I got myself the Bergeon ergonomic oiler set, an inexpensive Chinese stereo microscope, and after that oiling jewels holes and pallet stones has been become a lot easier and very precise. Quite an investment at the time not knowing if my interest would take off, but it did and I now consider these tools some of my most important alongside good tweezers and screwdrivers.
Thank you for sharing your nice experience about how and why choose this tool. It's very helpful for me and others. Thanks again.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
