Bergeon Cannon Pinion Remover
Seth
Good Afternoon,I hope you are all keeping safe and well during this tough time.I wonder if anyone can help me with a small problem I have.I have just purchased a new Bergeon Cannon Pinion Remover and it will not remove any cannon pinion's from wristwatch movements as when the lever is fully depressed the collet will not close enough to grip the pinion it just is too big for watch pinion's.It works on large pocket watch movements but not on wristwatch movements of various sizes as I have tried 5 different movements with all the same results.I enclose photos of the new tool as received from H Walsh I await any replies before I send this back for a full refund. Regards,Seth.
When I bought mine the information on CousinsUK clearly stated: "for small and large watches” and ”adapted to all calibres”. It was not, and Cousins changed the description (added: "Can lift cannon pinions diameter Ø1.00 to Ø1.80mm") and refunded the money. I record a video about it...
Hi to you all,just a quick update on this Bergeon Cannon Pinion Remover 4854, I emailed Bergeon to say how disappointed I was that this item will not remove pinions of 1.0mm and less and Bergeon have said that this 4854 Cannon Pinion Remover is for pocket watches!! They suggest that I use either a Presto type remover or Hand levers (hairspring collet type) and they have even enclosed their part numbers and PDF images of these items!!!! Regards to all and keep safe,Seth.
Good Morning to you all and I hope you are all keeping safe and well.Just a quick update on my Bergeon Cannon Pinion Remover,l decided to keep the tool and investigate if I could alter the collet size somehow.Well after disassembly of the tool and looking at the collet size I found out that with a small alteration of a Dremel collet using my Lorch lathe I think I might be on to a winning situation!! I will keep you posted on this.Regards to all and keep safe,Seth.
Cut a piece of thin aluminm foil, like 1.5mm by 3mm, warp it aroumd a screwdrive about the diameter of canon pinion, role as you would a cigarrete, you are making a tube of aluminum, place the tube on the CANON pinion, you have increased diameter of the canon pinion by the tube's thickness, the tool grabs the bigger diameter.
It works.
Good luck.
  • jdm changed the title to Bergeon Cannon Pinion Remover
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
