sieko sportsmatic, automatic wristwatch
wi33ard
30 minutes ago, wi33ard said:
is there somewhere other than seiko where i can get this item serviced/repaired? thank you
Of course there are independent watch repairers, however be aware that if for example the value of your Vintage Seiko is 100 (USD EUR, GBP,?you didn't event mentioned where are you located), a typical repair / service bill can easily be 200.
2 hours ago, Klassiker said:
Lots of places. If you tell us more about yourself (clue: introduce yourself) and describe your watch, someone Here will be able to help. If you are really a Wizzard, I also wish it could be Christmas every day.
If he was a real Wizzard his watch would be working.
i am in london. the watch has a serial stamped on the rear which reads 805958.what is strange about this watch is that where it might normally say water resistant, this is water proof
i was a real wi33ard, i would not need a watch
Seiko marked their warchtes water proof until about the end of 1970, and started marking them water resistant since 1969. So yours should probably be a 1970 watch, as its reference indicates (80 = August 1970/80/90...)
This is from 1969
EDIT: Philipk5 in the post below is correct, 80 means October 1968, not August 1970.
Edited by aac58
There should be some more numbers/letters on the caseback which should help identify the movement.
The use of the words "water proof" was replaced with "water resistant" some time ago (1969ish) by Seiko.
The serial number quoted indicates the watch was made in October of a year ending in 8 (ie 1968, 1978, 1988etc.
Hope this is useful and helps.
(I am pleased with myself for regarding who could do repairs not saying .......Roy Wood!)
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
