Old Swiss movements
Mr0ldschool
I have a pair of nearly identical Swiss movements from a company called LD Seine from Locle. Owing to the lack of any information to be found, I consider them members of the enormous body of generic Swiss watches. Since they are both key wind, key set, I'm inclined to think they date to somewhere in the vicinity of the 1860's, but I'm no expert. They actually both keep pretty good time, but I only have one good case between them. They do both have issues though. The first one I bought needs to be fully taken down and lubed. It will keep good time for a few hours then just stop. If you restart it, it may run for a few more hours or stop again pretty quickly depending on how it is feeling. If you listen while it is running, it sounds squeaky, so my impression is that it needs to be lubed.
The second one looks significantly cleaner to start with, having an almost gilt look to it, but after 6 or 7 turns to wind it, the mainspring slips and you have to start over. As such, you get maybe 8 or 9 hours and have to wind it again. No random stopping though.
I wanted to hit the easy button and just swap the barrel and its bridge dirctly from the first to the second, but the bridge has a locator pin in the wrong place and the screw holes are slightly different too. So then I thought perhaps I can move the barrel from the first bridge to the second. The problem I have at this point is that the barrel is held fast to the winding arbor and I can't see how to separate the two. I'm hoping someone here knows how they are held together and can point me in the right direction as to how to do this step. The last thing would be to try to find a replacement mainspring and try to do a better job anchoring it in the barrel, which I'm not totally against, but that still will require the arbor to come off. Any ideas? In all photos, the first one is on the right.
I hope somebody can show me what I'm missing.
Thanks!https://uploads.tapatalk-cdn.com/20200921/e38ed9d86f2267bcf0f8184dc994460b.jpghttps://uploads.tapatalk-cdn.com/20200921/8444ea69bdc57835bc7835b6a98804e3.jpghttps://uploads.tapatalk-cdn.com/20200921/4445c2759bf108af1abe7a78a8fcbf0e.jpg
Sent from my LGUS992 using Tapatalk
I think that if you could post clear pictures for each of the issues you are having others would be in a much better position to offer help.
Edited by jdm
Here are the arbors on the bridge side. There had been a piece that covered the arbor wheel and was held down with four tiny screws. Removing it didn't have any change in the bond between the arbor and the barrel, and in fact only one movement still possessed it.https://uploads.tapatalk-cdn.com/20200922/9db4f75f8d7b32f0704d910279f1adce.jpg
I'm guessing the problem is you're using Tapatalk Whatever the heck that is and instead of attaching pictures from your folder of your hard drive it's attaching links of where the folders of Image location. Occasionally because I feel like being a nice person and I wanted to see the pictures there down below. You might look into a different app that lets you actually attach pictures rather than links.
As far as swapping parts go because the age of the watches their almost custom-made's swapping parts really isn't the best approach.
Because of their age lubing would be nice but cleaning before you Lube would be better.
Then the word of the day for you to learn is suspended barrel.  that term sounds vaguely familiar? It's amazing what you do if you do a search of the messageboard there's probably more references but this one looked vaguely familiar like of seen it before?
https://www.watchrepairtalk.com/topic/14947-mainspring-barrel-not-secured-on-one-side/
I post on numerous message boards with Tapatalk and it doesn't do that on anu other ones, so I'm disinclined to think that is the problem. I will have to dig into the settings to see if I can find an answer.
And to answer your question, no "suspended barrel" does not sound familiar. Thank you for pointing it out, but expecting me to know the terms I'm looking for before asking what they are is putting the cart before the horse. I'm just learning this new hobby.
Looking at the other thread, it looks like what you're saying is that the winding arbor is threaded onto the inner arbor, and both sides do have square shapes which seem to support the notion.  Unfortunately I don't have anything small enough to safely grip the tiny inner arbor. I was able to get the mainspring to come out, however, by unseating it from the peg that it is held by on the arbor and then gently letting it out until it was fully unwound. It is a basic spiral mainspring.  The inside of the barrel only has pegs to hold both ends.  The other barrel seems like it has a t shaped peg or possibly a very short screw to hold the outside end.  I don't know if this means damage, or if it was designed this way.  I will upload some pictures shortly.  I'm working on transferring them from my phone to my computer...
In the first picture, I've circled the "peg". It has no ability to hold down the end of the spring, shown in picture 4, when it has a few turns on it.  It simply lifts off.
The second picture is a closeup of what looks to me like a tiny slotted screw holding down the other spring.
The barrel in the first picture also has two holes that I will show in subsequent pictures, which look like either previous mounting places, or potential ones.  I'm open to suggestions about the best way to proceed.  Does anyone sell the type of screw that would do this job?  Would an "S" type spring hold in place better by wanting to press outward against the barrel at the end?
Thank you all for taking the time to look at this.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
