Which EB 8800 part?
AshF
Hi all,
I have an EB 8800 on the bench and the third wheel has broken.
I see from the service sheet that this piece comes in two flavors.
But I don't know which one I need.  Cousins have them both in stock and listed as...
Third Wheel ( 210 ), EB 8800
Third Wheel, Upper Conical Pivot ( 217 ), EB 8800
Any ideas how I could find out?  I would hazard a guess that I need 217 as the remaining pivot I can see has a conical end?
Many thanks,
Ash.
Yeah, I thought the pivot was broken, it looks a bit short.  I will use this broken part to practice on.  Not to derail my original question, but by peen do you mean hit it with a staking set to close the hole a little?  If so, which stake would you use?
The hole looks shagged to me and will likely turn untrue if just closed with a stake.
I think you may need the cone bearing type as it’s unjewelled - check the remaining original pivot to confirm the profile of the tip.
