Movmements makers mark???
gary17
I would guess the 1194 is the serial number and the maker is JC.
Early Cortebert had a stamp JC but not looking like that, maybe an 30's art deco..
One need to see the dial and back side to pinpoint the manufacturer.
Well on this one we only can see the actuall brand mark JC, the reason one want to see the dial and back is the old books just goes by black and white pictures of them.
Here you can see the brand for Cupillard from one of these books.
