Regards from the Netherlands
iloveoxytocin
Hi all!
As it is stated you'd like to know a bit about new users, here's my story.
I like to learn about and tinker with with setups for making espresso and beer. Since corona, I took up an interest in repairing my own mechanical watches. After having completed the first and second part on WatchRepairLessons and completing the stripping down, cleaning, lubricating and re-assembly of a UT 6498/CHI3620M movement I'm now working on a barn find pocket watch. After re-assembling that pocket watch, I'm planning to mod my SKX031 and give it a good service.
I really like the culture around repairing watches - I think it's quite different than only collecting them. Opening up a new watch, peeking inside, and knowing how all the parts work together is both satisfying and enchanting.
Wilkommen!  Here will you find a group of friendly people willing to share a wealth of knowledge and experience with timepieces!
You have peaked my interest with mention of the pocket watch.  I prowl about at flea markets and estate sales to pick up non-running pocket watches, and I restore them to running condition, polish them up and, if I do not grow too fond of them, I will sell them later.  This, and my part time repair service, helps a little with the bills.  Please post pics of your own watches too.  And feel free to ask questions; there are many helpful people here.
On 9/20/2020 at 1:39 AM, Tudor said:
Welcome! Aren’t they fun?
Defenitely!
On 9/20/2020 at 2:24 AM, HectorLooi said:
Welcome. What a cute name you have. Are you medical? O&G? Or a new parent? :Laugh:
I've assisted in psychological research into OT quite a while ago, that's why the name.
Thanks! Yes, I think this is the right place for questions. Cool to hear you're browsing fleamarkets for pocket watches and restore them. Also nice to know that this may provide some kind of income... I'll post a picture of the finished watch  here
  • 5 months later...
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
