Crown stem question.
Kevo
Hi guys. I've had this Pulsar y182-6a00 for many years and it has great sentimental value to me. I believe it has a Seiko movement and is basically a Seiko 7T42-6A00 clone? I stopped wearing it back in 2004 as I manged to lose the main (Time/Date) Crown. But recently I decided to try to get the watch up and running again, so I left it in with a jeweller to be repaired. Unfortunately he was unable to find a crown and stem so just moved the alarm crown and (possibly) stem into its place so I could at least set the time and date.
Id love to get a replacement main crown and stem and have the watch fully functional again. I think I could replace everything easily enough myself, and having done some online research I believe these items are still available. However I am not 100% sure about stem lengths. Will the time/date stem and the alarm stem be the same part and the same length, or is the Alarm stem completely different and/or shorter?
Just hoping you guys could point me in the right direction with regard to parts required and maybe offer some useful advice?
Many thanks in advance.
Kev
I would guess the main crown is larger diameter.
The watchmaker May have trimmed the stem to fit but I’m going to guess it wasn’t trimmed. Check the parts list and get the correct main crown, which may come with the stem attached. Seiko, for the divers anyway, often supply the crown and stem assembled.
Note that if the original stem and crown were lost, there may be parts needed for the keyless to be sure the new one doesn’t fall out...
Post up your findings and we’ll try to help.
Thanks @Tudor
Yeah Ive managed to locate the correct diameter crown and stem online, but the stem seems to be quite long, so I'm guessing it's for the time/date only. I cant find a shorter one for the alarm, so I'm going to try to maybe shorten the Time/date stem. Its worth a try anyway. The crowns and stems seem to come as separate units that screw together.
I will of course post how I get on.
I like to thread it into a die plate, trim with wire cutters and back it out of the plate, which straightens the threads out. Sometimes I’ll polish it before backing it out if it was an ugly cut...
if you’ve not trimmed stems before, get extras and wear eye protection when trimming. They are hard and the bits fly fast and far.
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
