Dial feet repair - All techniques
Hi there, I've had to use dial dots on old seiko 5 watches because of broken dial feet which is common on some older ones. Generally speaking a screw driver gently prying will easily remove the dial without any difficulty or damage as they are only holding the weight of the dial in place, as watchweasol said you have to make sure that the dial is spot on before sticking, or you will have to remove and try again.When service time comes around just put new dial dots on again no problem. No need for shellac. Hope that's what you want to know
Edited by Graziano
I have used these with a drop of epoxy and these feet were very successful.
My technique was to put the feet into the movement, for a couple trial runs of setting the face in place on the movement resting on the feet pads.  In my case I used a small O-ring around the Cannon pinion output that the dial hole would center on. I would then put a drop of epoxy on each pad and lower the dial into place, centered around the pinion o-ring.  I should note that I put a thin layer of cellophane (saran wrap) down over the movement pressing the feet through it so that there was no chance of epoxy squeezing out onto the movement.
Having an engineering background I understand sheer force, and there's a lot of surface between these pads and dial-back, providing more than enough strength to hold the dial for many years (providing the epoxy does not give out). Not as good as welding but second-best and I was very happy with the outcome.
Edited by Wdc
Food for thought!
I should add for those with problems regarding clearance.  On one dial where clearance was an issue, I placed the pad face down on a diamond filing plate,   working it back and forth, reducing the thickness of the pad,  giving me the clearance I needed.  I was also prepared to file away sections of the pad had it up hit anything in the mount, but it was not necessary.
Providing you don't file the pad too close to the post, you should be fine. This being said, there are watches were they just won't work.
Good luck to anyone using these
There has been some discussion in the past regarding the possibility of glueing dial feet. No really good glue was reported. However, my dentist suggested the use of 3M dental cement. She uses it for pemanent gluing of crowns etc. The strongest for metal cementing is  3M ESPE  RELYX UNICEM 2. It is expensive but available on eBay with some limitations according to country. Here is an example of a test on a scrap dial.  6 mintes working time and after setting at room temperature for one hour I was able to lift, with the dial foot held by pliers, a 500g weight placed on the dial. Good enough as an alternative emergency repair when soldering could harm the dial finish.
  • Thanks 2
That's good to know!
You're right about the price... Ouch!
Years ago I used to use a product called Evo Stik TX 528 thixotropic contact adhesive to glue 8 x 4 foot sheets of stainless steel to walls and ceilings and just about anything else. It's adhesion was quite amazing. Not quite in the ball park of what you're talking about though, but it would be interesting how it did with dial feet.
There is a less expensive single-use version of  this cement called the 3M ESPE  RELYX UNICEM APPLICAP.  But it needs two tools, the first to crimp and mix the components and the second to extrude the cement. If you have a friendly dentist who would lend the tools this could be a low-cost solution.
Edited by Watcher
grammar
You might like to explore the world of surface mount electronic component assembly too. For example if you need to dispense tiny amounts of solder to fix dial feet in the traditional manner, you could borrow some tricks from SMD assembly.
Solder paste in syringes. This comes as leaded and lead free. I would suggest using the stuff with lead in as it flows better, and melts at a lower temperature, this minimising the heat that will transfer to the dial face, but ROHS stuff is available if you prefer to avoid lead.
https://www.ebay.co.uk/itm/Solder-BGA-SMD-Tin-Welding-Paste-Flux-XG-Z40-10CC-Needle-Soldering-Glue-25-45um/132416227698?hash=item1ed49f4972:g:pTQAAOSwCcZaHQXn
Just grab the keywords from that example and look for similar stuff.
There are also several different types of glue. For example single part "red glue".
https://www.ebay.co.uk/itm/FUJI-Seal-glo-NE8800T-SMT-SMD-Red-Glue-Adhensive-for-BGA-Chipset-Solder-RoHS/171643196779?hash=item27f6bb556b:g:g-0AAOSw6sRa3bSt
UV cure glues, like  LOCA Liquid Optical Clear Adhesive, often used for cellphone glass
https://www.ebay.co.uk/itm/TP-2500-UV-Glue-LOCA-Liquid-Optical-Clear-Adhesive-For-Cellphone-Glass-Lens-cu/283626728293?hash=item4209786b65:g:v2wAAOSwBChbXcWg
You would need a UV cure lamp for this, but there are lots of UV LED torches and UV cure nail polish devices to be had for a few dollars which will do the trick.
There are also specialist hand tools to "pick and place" various tiny electronic component items that might prove useful with watch components.
Edited by AndyHull
Slightly off topic, but has anybody tried using dental cements to repair enamel watch dials?
https://www.ebay.co.uk/sch/i.html?_odkw=3M+ESPE++RELYX+UNICEM+2.&_sop=15&_osacat=0&_from=R40&_trksid=m570.l1313&_nkw=dental+cement&_sacat=0
There are any number of tools and colour options, so it should be possible to place the repair, and colour match the original finish with a good degree of precision. Would this work? It seems it should, as tooth enamel is similar in harness to the glass enamels used on watch dials, and dental cements would therefore seem like a good match in terms of bonding, flexibility and so forth.
Andy Hull, the solder paste at the top of your post looks interesting.  I'm trying to repair some modules from quartz watches which are mostly damaged by battery leakage, so some tracks eaten away, pusher contacts vanished etc.  I'm dealing with features like closely spaced 0.2mm wide tracks, soldering 0.1mm wire on top to regain continuity. It's the nearest to micro-surgery that I'm likely to get and my success rate with 22g solder and a needle point iron under a microscope is not great.  Would the solder paste be any easier to use do you think, and would a hot air gun be a better bet than a soldering iron?  I'd appreciate your views.
Yes, I'm a dentist and I have tried. The problem is, in dentistry, we are trying to get our materials tooth coloured and translucent. Dental materials will not mask out darker material beneath it.
Recently I experimented with UV cured nail polish. But again, the colour saturation and opacity is not enough. I can get whites almost the same colour as porcelain dials by adding titanium oxide powder and blending it till the opacities match. UV varnish is quite viscous and cures with a substantial film thickness. For porcelain repair, it might work. But for touching up printed designs, maybe not so good. Another problem is matching the surface gloss.
One more thing, UV varnish doesn't adhere to metal that well. Probably when this lockdown is over and when I get back to my clinic, I will experiment with priming the metal with a dental bonding agent first.
I have not tried repairing a watch pcb yet. But for bigger pcbs with track damage, I will do point to point repair with a thin strand of copper wire.
You will need sufficient good copper on the board to do this. The kind of damage I see when a battery leaks is usually so bad that there is no copper left on the board. I haven't found a solution to this kind of problem yet.
    the path of rentance is useing  double back tape.  vin
It is possible to replace the entire track, using self adhesive copper tape. This is a delicate operation, and I generally don't rely solely on the copper tape's adhesive, but instead use epoxy or at a pinch cyanoacrylate. Once you have the new track laid down, with care, you can bridge solder to whatever remains of the old track, but a better bet is to solder a fine strand of wire across the joint to join the old and the new. If the PCB material has been eaten away, then you will need to fill in the hole, and this is also best done with epoxy.
This video is a reasonably good example of how this process is completed. Working on watch modules of course adds an extra layer of complexity, but it is doable.
Edited by AndyHull
  • 4 months later...
I have 2 dental spot weldind cum soldering machines. One from the 70's and the other only a few years old.
Both are able to melt dental solder which has a melting point of about 700°C. I got a bottle of low fusing solder paste recently but I haven't tried it out yet. With normal electrical solder wire, I managed to get a good joint but not without creating a singe mark on the face of the dial.
It would be good to know the soldering parameters of a proper dial feet soldering machine.
Indeed.
It came with some solder paste thrown in. But I have also purchased some paste as recommended by another BM a long time ago - apologies, cant remember who. And so, we shall experiment and see.
The only real success I have had (no fancy machine,,) has been with solder paste which works at a low temperature . On the dial side I had it resting on a damp cloth.The tricky bit is the correct positioning of the new dial feet especially if it has a date window.
There was a discussion on the subject right here on WRT like eighteen months ago,, Someone said he used to solder dial feet all day at a bulova repair center it was, spoke of lower temperature , less than 400 I beleive, emphesised on prep the spot the feet solderes to, used grind stones to flatten the remains of the old feet and dril bit to make dent where the feet was to sit in. claimed no damage to the paint.
Be nice if I can find the thread.
Hey guys! I recently got the above mentioned tool and I have an old Rolex here with dial dots holding on an aftermarket dial. The dial has some damage due to other issues going on with the poor watch being abused, but the client doesn't want to opt for a new dial.
I really dislike dial dots and glues inside of a movement whenever I can avoid it, but I'm a little concerned about damaging the dial finish with even a very precise welder like this.
Does anyone have experience tacking dial feet on with a laser or pulse arc welder? I've seen some resistance soldering techniques used, but no info on this in particular. I think it can work, but it can't hurt to reach out for tips. Heat sinking, settings, anything like that is a bonus.
Thanks a bunch guys! Always fun coming to the forum.
