Peter
Pedro
Hi everyone, I have a Swiss emperor chronograph with a landeron 248 movement.  The backplate reads 248 O W. The problem is that the seconds hand it came with was the wrong size and kept falling off when the fly back button was pressed. I don't know the size of the tube of a replacement seconds hand or where to acquire one, any help much appreciated.
Peter.
Hi, my first post would not allow me to upload pictures. I have tried to replace the seconds hand with some spare seconds hands I had but they were for conventional watches and the tubes were to small. I know that this watch takes a larger tube but I don't know the size it takes.
Thanks for the answers, trying to find a seller that deals with these specific parts is proving to be problematic. A seller on eBay is selling a complete set of landeron 248 hands but the bid's are starting to go high and I only want the centre seconds hand. 0.25 is a good start so I will concentrate on that. I have experience in removing hands and dials as I re-illuminate watches but I haven't tackled a chronograph, so I will leave that option alone. I didn't properly introduce myself on my first post so my name is Peter and I am from Liverpool, England and have been collecting watches for about 5 years. I also repair and refurbish when possible. I have a certain leaning towards pre 70's Omega's, but I have some others which I like such as Zenith and Ollivant and Botsford. Many thanks for your input and I hope to help others on this forum especially on the subject of Omega's or re-illuminating dials and hands if I can.
Kind regards.
Sorry I did not have access to the pictures.I presume the hand you are referring to is the hand that sits in the middle of the dial. I call it the fly back hand because when used it re-sets back to the 12 o’clock position. Because of this action it has to has to have a really tight fit, if not it drifts away from  the 12 o’clock position. Cousins are good source for watch hands.
Hi, I have checked Cousins and found two chronograph hands that may fit the bill. Both are 16mm long, one is 0.25mm diameter and the other is 0.27mm. I will buy both and see if either does the job. I will let you know the result when I receive them.
Thanks again.
  • 5 months later...
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
