Regulating a watch in London
east3rn
Hello.
I have a friend who is having a issue with his Seiko watch.
Watch is running a bit slow around -40s.
He wants to regulate the watch but he has no experience working on watches.
He took it to a local watchmaker and he was told that the watch should be serviced and
it would cost 300 pound which is as much as the price of watch itself.
Is there any watchmaker in London who can help him just on regulating the watch?
Thank you.
I always appreciate your help.
Sounds like a bad idea to just regulate the watch without making sure it will actually work and run well. It's like tryning to tune your car without changing the engine oil and I would recommend against it. It may work for a short period of time but it will break and stop all together before you know it without a service.
Perhaps someone on the forum  knows someone that may do it cheaper but that is not an authorized watch service center ?
What type of Seiko is it ? A picture from the caseback would tell us more.
Edited by Flubber
6 hours ago, east3rn said:
He took it to a local watchmaker and he was told that the watch should be serviced and it would cost 300 pound which is as much as the price of watch itself.
There is a little chance that the repairer has noticed something when looking at the watch on the timegrapher. Your friend could go back there or somewhere else and take a picture of screen to be posted here. With that one can give an educated guess about the watch.
BTW, now that the current Seiko Alpinist has been discontinued evenused ones do trade for much more than 300 pounds.
We can't and shouldn't assume that the watch is not working well. Perhaps the owner is a demanding one about timekeeping and want near quartz accuracy after reading that some 6R15 do that.
Luckily isn't exactly like that. It takes much longer than a "short period" for a mechanical watch to show problems due to lack of service. In fact it may not even break ever.
3 hours ago, rodabod said:
Maybe try taking it to Alsal watches on the strand and explain that you simply want it regulated. This assumes that you don’t want it cleaned.
It may also be worth asking them to demagnetise it.
Thank you.
So sad that I could have helped him right away if I was in London.
I will try Alsal watches.
I hope regulating the watch works :)
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
