Regulating a watch in London
east3rn
Hello.
I have a friend who is having a issue with his Seiko watch.
Watch is running a bit slow around -40s.
He wants to regulate the watch but he has no experience working on watches.
He took it to a local watchmaker and he was told that the watch should be serviced and
it would cost 300 pound which is as much as the price of watch itself.
Is there any watchmaker in London who can help him just on regulating the watch?
Thank you.
I always appreciate your help.
Sounds like a bad idea to just regulate the watch without making sure it will actually work and run well. It's like tryning to tune your car without changing the engine oil and I would recommend against it. It may work for a short period of time but it will break and stop all together before you know it without a service.
Perhaps someone on the forum  knows someone that may do it cheaper but that is not an authorized watch service center ?
What type of Seiko is it ? A picture from the caseback would tell us more.
Edited by Flubber
6 hours ago, east3rn said:
He took it to a local watchmaker and he was told that the watch should be serviced and it would cost 300 pound which is as much as the price of watch itself.
There is a little chance that the repairer has noticed something when looking at the watch on the timegrapher. Your friend could go back there or somewhere else and take a picture of screen to be posted here. With that one can give an educated guess about the watch.
BTW, now that the current Seiko Alpinist has been discontinued evenused ones do trade for much more than 300 pounds.
We can't and shouldn't assume that the watch is not working well. Perhaps the owner is a demanding one about timekeeping and want near quartz accuracy after reading that some 6R15 do that.
Luckily isn't exactly like that. It takes much longer than a "short period" for a mechanical watch to show problems due to lack of service. In fact it may not even break ever.
3 hours ago, rodabod said:
Maybe try taking it to Alsal watches on the strand and explain that you simply want it regulated. This assumes that you don’t want it cleaned.
It may also be worth asking them to demagnetise it.
Thank you.
So sad that I could have helped him right away if I was in London.
I will try Alsal watches.
I hope regulating the watch works :)
    • Showing state of hairspring on receipt, backplate & 'dished' wheel.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?       Have you seen this video, he shows how to determine where the indents go ?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
