Eta 251.262
Hi all
recently purchased a Longines with a Eta 251.262 non working movement. After a quick look around I have managed to get the watch itself working but only the minute recorder on the chronograph works, I get nothing from 1/10 or second recorder. I know these movements are not that expensive to replace but I just wondered if any one has an idea of what’s wrong. Is it simply they are electronic and there is nothing to be done?  Thanks as always.
Ok. I’m more familiar with Seiko chronograph circuits, but is it easy to check the condition of the switch terminals? On the Seikos there is a very fine layer of what is basically PCB track which forms the switch terminal and this can deteriorate.
If you have the ability to, then obviously you could measure the voltage across the coil while it is active.
It depends on the multimeter. You may still be able to detect the pulse in terms of voltage. What is more difficult is measuring current draw since it is in the microAmp range, but you don’t need to be concerned too much with current drawn yet.
Maybe see if you can detect a voltage across the coil of the working sub-dial. Although it would be a pain having to wait a minute for every pulse. Unless you could switch it to zero-ing mode and set it flying around.
    • Not SS but very slight wear on the underside edges have a little brass showing under magnification. New crystal arrived £3 with tax. Nice champaign dial color.
    • I also just realized I had that tech bulletin saved...but in French for some reason 🙂 No, I don't speak French. 2172_Bulova 11AOAC 11AOACD 11AOACB.pdf While parts are drying I'm on the hunt for a replacement crystal. I can measure the opening and get a generic one, but it'd be nice to find out what the original looked like first. Of course, case code 3093 does not appear in any of my reference materials. JulesBorel lists a C3093 case code, and shows Bulova part # 1222-5. Does anyone have information on this guy? I found a thread here talking about how the -5 is the height of the crystal, but that's as far as I've gotten. I also found one site that claims to have it in stock, but before I risk my $20 I'd like to confirm it's the right part.
    • Thanks for the replies. I did the job today and found that the oversized stem fitted just perfectly into the worn mainplate without any adjustment. Original stem diameter was 1.24mm and the oversized was 1.40mm. I did have to make an adjustment to the setting lever though. The small pip that engages with the groove in the stem hub was slightly to wide. I made that a bit smaller with a fine file. Don't ask me why that was too big, it just was. All working very well now. No wobble and not pulling out. New crown fitted as good measure.
    • Hi Vandan. Hi from a fellow newbie! Marshall has got a lot to answer for hasn't he! 😄. I also got hooked to this hobby after watching his videos.  Good luck with your journey to service your Grandfather's watch.   Nick
