WHAT S this????
gary17
Hi guys
Left this over night in white vinegar and it want come off. So far i have washed it 3 times in ultasonic  and used ,petrel,white spirits ammonia and it aint shifting.Its like the metal is dissolving.
Also a bridge i left in has come out all blotchy pink blotches if i did not need it i would laugh but jeez.
Any ideas ???
cheers
gary
I have not used vinegar before for cleaning watch movements but I think you have indeed dissolved some of the metal. I have recently done some photo etching (failing to etch some gears) and I recognise the description of having pink blotches on brass (I assume the balance is brass).
Unfortunately the only way I found to remove the discolouration was to remove it mechanically with abrasives. I expect that the parts have probably corroded quite considerably after being left in vinegar and are unlikely to be usable. It probably wouldn't hurt to try cleaning them with some fine wet and dry but I wouldn't get your hopes up.
I probably agree with Nucejoe.
I would say what you are looking at is called Pit corrosion, as you cleaned a corroded part with vinegar it of course took away the rust and left the part full with pits and oxide residues. So as the most here already said it is and was an write off from the begining .
Only use vinegar or other acids to take away surface rust. Use a glass fiber pen to wipe off the residue and  to see how much is gone. Afterwards you always have to polish the part up a bit.
I see it is the Landeron 48 bridge with two holes by the big one, almost threw in one for a Landeron 248 instead.
But here we go this should be a better part to practice on, I throw it in the kit for you.
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
