How to make shaft hole in hands 0.5 mm bigger ?
Flubber
I ordered a new quartz movement to replace the old Ato-Matic movement. and it has arrived. However, even though the minute hand fits perfectly on the euroshaft on the new movement the hour hand do not fit. I thought there was some sort of standard but there you go. The shaft on the movement is made of plastic and seems to be exactly 5.0 mm in diameter but the hole in the hour hand seems to be ~4.5 mm in diameter. So my question is what to do sbout it ? Is there a way to make the hole in the hand bigger ? Using some sort of reamer ? I could perhaps order new hands but I rather not. Any suggestions appreciated.
HI  Other than reaming (broaching )the hand to fit not a lot you can do,  other than new hands. Hand sizes differ according to the movement and there are a great number of styles.  There are    round shaft,   euroshaft,   "I" shaft. The I shaft and euroshaft are similar and the Min hand has an elongated fitting and the hour hand is round,    so carefull attention with a broach will probably do the job but after every turn of the broach check the fit.
As I suspected then. But is it possible to make such a large hole bigger by reaming (broaching) by hand ? The hands seems to be made of a rather soft material (brass ?) so perhaps it is possible. I have no broaches or reamer tools so any suggestions on what to use (ie buy. Love buying tools albeit expensive ! ;-)
@watchweasolWhere did yo find that picture of the hands ? I think I spot the exact same model as the ones I have on my old clock there.
Hi Broaches can be bought either singly or in sets depending on what you want, they also come in varying sizes as shown in the following link   https://www.cousinsuk.com/product/0020-to-080mm-bergeon.   The picture I salvaged from ebay but the same can be found on ngclocks.co.uk   clockparts.co.uk     and also cousins uk                    cheers
13 hours ago, VWatchie said:
Just wondering; provided a suitable size is available, could a jeweling tool reamer be used for this job?
If you are refering to a Seitz jewelling tool, I don't think there are any reamers 5.0 mm diameter.
I don't like the idea of reaming. It removes material and weakens the tube. I would put the tube of the hand in a slightly larger hole of an anvil block and insert any tapered tool and expand the hole. If you can't find a tool that fits, take a large iron nail and file it to a slight taper of about 2%. If the resulting hole ends up too big, you can shrink it by clamping the tube in a 3 jaw chuck.
I was, and you're right about that. I got it wrong and thought we were talking about 0.5 mm. Guess I had a senior moment :rolleyes:
As a general rule I guess it's good idea to avoid removing material whenever possible. Perhaps a smoothing broach could do the job?
    • An incabloc spring? About 10p at the current price 🤣
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
