New crystal for a Seiko 7T62-0DB0
6 hours ago, arnaudG said:
I am looking for a new crystal. Here is the reference: 310P03HN03
It's a regular flat crystal, you can fit a generic cone for $1. Or a sapphire to not worry again about it.
Thank you for your help. Both options are reasonable.
Can someone explain me what the "310P03HN03" reference means? I assume that 310 refers to 31.0 mm diameter. What about the thickness? is 03 for 3mm? I don't have any measuring tools. What about the bevel if I go for a custom crystal?
Thanks!
Edited by arnaudG
Have a check of the attached. You definitely need digital calipers when working on watches, as well a crystal press.
Crystal Codes.pdf
