Case issues !!
Having been in the business for many years I have recently come across a couple of watches that have had issues I’ve not seen before. Out of the case the watches work perfectly with great amplitude and timekeeping. Once inside the case and the case clamps are tightened, the timekeeping is terrible and both watches I’ve serviced stop !! I’ve tried tightening the case screws in various orders and tried the stem in several combinations but to no avail. The only conclusion I’ve come to is distortion of the case.
Loosening of the case screws solves the issue but loose screws are not good!! Any ideas??
The honor goes to other watches too, not just Omega.  I have a Peseux that dose the same. My late watchmaker showed one that had no screws to tighten, stopped without hands and crystal or stem installed.
Sorry Peter don't mean to sound discouraging or disagree, most common cause is the dial plate though.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is. I've attached a lesson regarding mainsprings, focussing on the size and strength of the spring within the barrel, you might find helpful. Unfortunately it is a PDF converted from a PowerPoint presentation, but only a slide was lost that was originally a video of fitting a mainspring   Lesson 5 The mainspring.pdf
