PLEASE HELP - crown tube tapping
Hello i have this very rare wwii elgin canteen diver. The crown is irreplaceable so keep that in mind. The stem broke and the other half is stuck in the tube and only a tiny bit is sticking out. I have tried everything from heating it soaking it in PB blaster and I cannot break it loose I’m pretty sure it is held in by glue or some sort of Loctite. Not to mention it’s been like that for 80 years and it’s rusted. I cannot get a tight enough grip on the tiny bit that is sticking out. I think the only way out of this one is to drill it out and then re-tap it with a number eight. However I do have micro drills And a crown tap set but this needs to be done with extreme Percision and I think it is a job for a watchmakers lathe which i do not have. I am wondering if there is anyone on this forum that can do such a task. I just need help I’ll pay whatever you want. I paid $1300 for this watch and if I can’t get this crown fixed it’s pretty much only good for parts.
Sent from my iPhone using Tapatalk61938228322__BCA92755-CC25-4EE1-A19D-604AFCD7ACB2.jpg61938222321__4FC83F38-C6BE-4073-90AB-7C501ADD00A9.jpg61938223888__1583BB9D-A6A2-459F-B658-357584B8EB6C.jpg
Hi  a bit sad, If it loctited in its going to difficult to remove in the whole. If the crown is all made of brass then using Alum (Aluminium Oxide) powder dissloved in hot water and soak the crown.  The Alum dissolves the steel but leaves the brass intact.  You are sure to get other opinions to consider and I wish you well
I considered alum but i think the crown is steel too. The case is parkerized stainless steel, so i will assume the crown is
No. The way it's done is with a crown (hollow) mill on a lathe or boring machine. I know becuase I am being taught by a Master watchmaker that developed the below machine exactly to do that. The hollow end mill is hand made with a triangle file and then hardened. One only cuts just enough tube to grab the stem safely. I hope you can find someone that can do that for you.
esatrice_998.jpg&key=576844ddeb0ab375d274adc4a700bf93a44c216a807bb1ac174d3a0216ce56ba
Do you think your guy can do it? I’ll pay whatever he wants. My only other option which is something I don’t want to do is basically grind the end of the stem down and re-tap the outside of the tube then use a stem adapter. Or Solder the stem directly to the tube. Both these options would be what I consider rigged and I am a stickler for details especially when it comes to these extremely rare watches
This may be a really stupid suggestion, but it can't hurt to throw it out there in case it sparks a better idea.
On a MUCH larger scale I've seen people use an arc welder, hook the ground to the part with the broken off "bolt", file the exposed surface of the broken threaded piece so it's flat, then hook the "positive" wire to a junk bolt that has a similarly prepped face, then touch the bolt to the broken off stud and the bolt gets welded to the broken off part. Then use a wrench to turn the broken off part out.
That said, if the stem broke in the first place whatever thread locker is holding it in the crown is probably is strong enough that what you tack weld to it in this manner would also just snap off.
What is the diameter of the original stem?
Answered in PM and for the record not for money.
My other observation is that on lathe, even a "model engineer" one with a collet chuck it is trivial to cut 1 or 2 mm off the tube.
Edited by jdm
Yes I have heard of that before but the problem is I don’t think there is nearly enough sticking out to weld. I don’t know the size I just know it is a tap 8 stem
I don’t think you want to attempt to cut into the existing stem as it will likely be harder than the crown pipe.
If it’s any consolation, I recently repaired an original irreplaceable crown on a £7k JLC Mk11 and it worked out fine.
There are many ways to skin a cat, but here is what I would do:
Firstly, I’d find out if the crown pipe is stainless, or at least significantly less likely to corrode than a carbon-steel stem. Usually this will be the case. Which opens up the opportunity to dissolve the stem in acid.
To dissolve with acid, you can suspend the crown such that only the end of the pipe is sitting in the acid. You can use an oiler to spread the rest of the pipe with silicone grease to acid-proof it. I’ve attached a photo of a crown from a 1980’s issued Precista military diving watch having this done just now. The corroded stem gathers at the bottom of the container.
Actually aluminium oxide is an abrasive grit, not soluble in water, and pretty inert.
Alum is potassium aluminium sulphate, water soluble and will dissolve steel but not brass, and not stainless steel.
I would be surprised if the crown were a plain carbon steel as this would make it rather prone to rusting as it's exposed to the outside world. If it's stainless or brass though then alum is your answer.
Ok It is 100% stainless steel. What is the correct name for the solution I need to look for. I will just go to my local Home Depot
What solution did you use
As @watchweasol alludes to it's an astringent used in old fashioned wet shaving.
I use this as I have it around anyway (being convinced that the peak of shaving technology was reached in the late 1800's to early 1900's and everything else since has just been marketing hype to part a man and his money) and it works fine.
Interestingly enough as well as a shaving product, and for dissolving steel, it also makes an excellent un-perfumed deodorant, and is used as a food preservative, so you might be able to pick it up in the food aisle at your local supermarket in powder form.
Phosphoric acid. I wouldn’t bother with alum as you’ll be waiting until next year for it to finish off!
Usually no more than about 3 days. Quicker if you keep it warm.
I do use alum, but I find it can be very slow when dissolving stems which are trapped as there is so little material exposed.
It seems not one grocery store has alum in stock but i can get phosphoric acid. The tube is stainless steel but it was treated and it is not magnetic. The stem however is since its carboned steel. Will the acid ruin the tube too?
I mix up my alum, put it in a urine container/jar, then I drop it into a thermos full of boiling water for 3 days. Longer if needed.
I'd persevere with the alum. It will eventually get the job done.
Seiko use stainless steel stems in some models. I have been unable to dissolve a diving watch stem recently.
Starting with the 1.3L model, ultrasonic cleaners come with heating. They are not expensive and ideal for maintaining a controlled temperature over time. Of course you would have to place the alum setup in bain-marie.
Whereabouts are you? If in UK I can send a small amount of Alum.
Cheers,
Phil
    • An incabloc spring? About 10p at the current price 🤣
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
