Identify Elgin movement
Hi everyone.
I picked up a nice Elgin wristwatch from the bay for around $100 Australian dollars.
It appears to have a broken Balance staff and due for a service.
There are no markings under the balance cock, how do I go about finding the movement ID to get a new staff?
Is it worthwhile trying to get it running? It looks a tad small on my wrist but I have a few vintage omegas in similar style. I'm not sure if it was originally a wristwatch or if it's a Hodge podge.
I might send the case to Canada to get a up on the rolled gold. It's very thick gold I might add.
I can measure the movement later.
Cheers Alex.
For the most part for Elgin if it has a serial number you go the pocketwatch database and look it up. Then if you're lucky on the parts tab ill Bill the finder parts. Unfortunately for balance staffs it isn't always that simple as there may be variations. Usually any time you restaffed any American pocket watch you always want to measure the before and after to make sure the replacement staff actually is the proper replacement staff that way you would avoid unpleasant surprises.
If you look through the parts go to the staff section you will get the image that I have below. You'll notice I highlighted something the staff conceivably has variations. Elgin unlike other watch companies for the staffs would have a part number but the part number would action referred to a whole bunch of staffs with variations. Typically it's just pivots size variation but other times other dimensions Very. Then when you order a staff online it may be a generic replacement that may not actually exactly fit the staff you have.
I'm attaching a second image it looks like I was correct there are some variations for pivots size. It would be really nice if one ear pivots still existed. But as a guess is this is a seven jewel watch it's probably the largest size which works out fine any staff would work then hopefully. Sometimes the generic replacement staffs are deliberately made over size as it's easier to reduce the dimensions than it is to add on to the staff.
Then one more image there's a reference to single and double roller normally that would be physically different staffs but in the case of this staff will work for either or so I variation in size you have will be the pivots.
https://pocketwatchdatabase.com/search/result/elgin/26620476
Cheers
I have found by serial number that is a 462 movement. I am now sourcing some parts.
I got the train bridge running well.
My balance is broken, winding wheel missing a tooth and the click is worn down.
Very interesting crown design. The crown setting lever is in the case/crown.
The movement drops out without having to release a setting lever screw. Very peculiar and clever.
Typically traditionally with American pocket watches and some Of the wristwatches this is what you have.
Also if you look carefully you'll notice that when the movement is out of the case it's now in setting. That's because the crown and stem in the case determined where the crown and stem are by the sleeve in the case.  If the movement is out it automatically goes in To the winding position. This then presents a problem if you're trying to run the watch as your now driving the entire setting mechanism. Watch manufacturers recognize the problem and Oftentimes provided a way to put the watch basically into a diagnostic mode which puts the watch back into running out of the case. Fortunately they all had slightly different methods. So I almost need to see the parts under the dial to tell you how to do it.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
