Help sizing for a new crown
Evening all
Sorry to ask such a basic question but I have never purchased and fitted a new crown so I really am having trouble with the measurement side of things. I have measured my current crown and the dimensions are as follows
4.88 width
3.61 length
The thread it fixes onto is 0.85
The trouble is I have looked on places like eBay and can’t find replacements with these exact dimensions. Would I have to buy a bigger or smaller crown and do some modifications or is it just a hunting game when I keep looking until I find an exact match???? I’m a complete newbie and any input would be greatly appreciated
Cheers guys
You will have to get whatever is closer. Other variables are the style, where the waterproofing is, case tube size, etc. Yes it's more complicated than it seems but if it's something simple and no pretense of perfection, something will fit good enough. Material houses may have more selection than Ebay.
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
