problem with Tissot C01.211
Hello dear watchmakers.
I have a Tissot automatic chronograph watch with C01.211 (which is based on Lemania 5100).
The one and only issue I have with the watch is that when I try to hand-wind the watch,
the rotor rotates violently, shaking the whole watch.
I have an another Tissot chronograph with the same movement and it winds very softly without any shaking.
I am about to take my hands on this watch to fix it.
Could anyone give me a tip on fixing the issue I am having??  I am quite new to chronographs and a little tip would sure be a great help.
Thank you.
The auto system on this caliber is very simple. The reverser is really just a pinion on the rotor which is held in one direction by a click spring. The pinion needs to turn freely (minus the spring) on the rotor, and be lubricated. When hand winding the pinion spins past the click; if the lubrication has become sticky the rotor will spin. Use a plastic pointed stick (or two) to remove the clip holding the rotor on, it's very easy to scratch the rotor with metal tools.
If you do a full service on it, beware of using alcohol on the date support (it's a full plate made of acrylic that covers the dial side)- alcohol will damage it. It's possible that the latest executions changed the plastic but I don't think so. I wouldn't recommend it as a first chronograph, it's a robust movement but has some tricky parts to deal with.
Here's a manual
18 hours ago, watchweasol said:
Hi   Lemania 5100 is used in the Omega 1045. I have attached the tech sheet for the omega 1045 and the technical instructions for the Lemania 5100.   Hope you find them us ful
1283_Omega1045 (2).pdf 429.16 kB · 2 downloads 5188_Lemania5100_Technical Instructions_Smaller (3).pdf 2.64 MB · 1 download
Hi WW,  I have an AS-5100 complete balance, fits zenith 5100, any relationship or interchangability with lemania 5100 or Omega 1045, or are the two different creatures, I wonder if spec of balance complete can be gathered from techsheets? or other sources?
TIA   joe
I feel truly blessed to be a member of this website.
I will take a look at the reversing wheel and hopefully get it working again.
I really appreciate all of your advice :)
On 8/9/2020 at 2:46 PM, CaptCalvin said:
Sticky reversing wheel.
23 hours ago, Nucejoe said:
Clean and check winder module, treat with epilame fixdrop, be prepaired to replace the reverser with new.
Good luck
Here's a manual
TIA   joe
Good luck
I hadn't seen the picture before making comment, though its ETA type reversers, never had worked on any, just got some parts in a watchmakers estate I bought years ago. I guess these last a lifetime, unless some parts break.
41 minutes ago, watchweasol said:
Hi Nucejoe     I have dug up the AS5100 tech and the 5200, the lemania and the Omega are already posted  so a comparisson could be made    cheers
AS 5100, 5101, 5102, 5103, 5104, 5106, 5150, 5151, 5152, 5153, 5154, 5156.pdf 1.94 MB · 0 downloads AS 5200, 5201, 5202, 5203, 5204, 5206 (1).pdf 2.59 MB · 0 downloads
Much appreciate this WW.  Regards
I have tried removing parts that seem to be part of automatic winding mechanism.
I cleaned them and put them back together.
However problem is not solved and movement is making clipping sound (this is new,  I got myself an extra trouble :<)
Plus, I feel that the rotor feels loose and wobbly, shakes on the pivot.
Would this be the cause??
Good luck
d
Here's a manual
15 hours ago, CaptCalvin said:
Yes if not reversing wheel then it's probably a wig-wag mechanism that's not wig-wagging. Either way it's a clutch mechanism that's become seized in one way or another.
1 hour ago, east3rn said:
However problem is not solved and movement is making clipping sound (this is new,  I got myself an extra trouble :<)Plus, I feel that the rotor feels loose and wobbly, shakes on the pivot.
Have you looked at the documents posted above? in your picture at least the winding click is missing. You need to fully understand the working of parts and their ensemble, otherwise you won't be able to diagnose faults.
in addition to cleaning did you use any form of lubrication?
did you notice in jdm's message above the reference to understanding the working of the parts? If the rotor feels loose it must rotate on something does that look worn at all?
A culprit is worn axle( that rotor gets mounted on)  or rotor bushing or loose axle mounting,  however worn or broken jewel, pivot or bushing anywhere in selfwinder mech can not be ruled out.
If all parts are okay, it is back to lube which don't seem to be as sensative on this as is on ETA type reversers.
Is the axle screwed or rivetted on( loose axle). Re-check all holes/ pivots and gear teeth under high magnification including rotor pinion.
 Do you have extra parts left in the tray?
27 minutes ago, CaptCalvin said:
What do you mean by "shake"? As in there is excessive play? Or that it vibrates up and down as it spins?
Good question, do you mean axle itself shows side shake? ( loose axle)? will you clarify.
I was luck enough to get a Tissot watch with updated version of the same movement(working fine)
I compared the parts side by side and tried switching the rotor. (the rotor does shake on the other watch as well)
It seems that there is problem with the rotor because the new watch was showing the same symptom with the rotor from the watch I was woking on.
Also I realised that on the new watch, the wheel that goes under the rotor was much closer to the pivot than the rotor.
So I tried putting the wheel on the pivot before putting the rotor instead of installing the wheel on the rotor first.
The symptom did get better, the rotor doesn't react as before and when the watch is facing up, rotor stays calm.
I added some photos for others to refer to.
Black rotor is from the new watch.
The updated version doesn't have the exact same movement number? Then updated does not necessarily mean that it's brand-new perhaps both watches are worn.
I don't see any pictures of the axle how does it look?
See part No 1400 on diagram.
Regards Joe
    • Hello!  Does anybody have this tool?  This is mine.  If you have one, does it look complete?  How do you use it.  (I have the instruction sheet but it's hard to read!)  thanks!
    • @JohnR725 that's very helpful.  I appreciate the time you took to give those instructions and post the pictures.  below is a picture of my staff, which looks identical to the ones you posted.  The approx measurements I got are: .772 on the left part of the staff; .715 on the right side of the hub; the hub is 1.107; and the overall length (minus the broken pivot) is 5.248; which seem to line up with the measurements you posted.  I didn't think to measure the pivot, which I'll do if there's enough of one left on the staff.  Thanks again.
    • Thank you to both of you!  I've been somewhat derailed by this quandary for a couple of days now. I am guessing that the point of the wider tweezers is to support the whole spring at the same time in an effort to prevent it going under tension... I have already discovered the Zen of a clutter free space, and trying to keep my work well away from the edge, however the most terrifying of the flights wasn't so short, I had my work in the middle of the table and nothing else around.  That particular launch was towards me.  I distinctly recall feeling the spring hit my left hand as it escaped.  I only found it by dumb luck, on the floor, between the legs of my chair.  I need to order a pack of replacements just in case.  I think I recall a thread discussing where to find them, and the differences between the clones and the authentic ETA ones, pointing out that they're not interchangeable (the clones being longer IIRC).  Now I just have to find that thread again.  What I haven't mastered is the zen of the search function here.  I'm sure I"ll get that down eventually. So this is similar to, but different from one of the posts I had found in my original searches (or maybe I'm just hallucinating, I can't find the post I thought I remember).  The bits about the corner filled in a gap in what I'd read before.  At least I have a more clear picture in my head about what needs to happen now.  Yes, I've learned about how touchy these springs are.  What I'm not sure I have a good grasp on is the understanding of what causes the spring to flex, other than to say "the slightest little touch"  I think I'm going to try a small bit of Rodico to position the spring next time.
    • I think it's stamped on the inside cover. 309 I think.
    • Hi all, needing a little help. I have an old Casio AQ-321G, but have no idea what battery it takes. I've looked around online, but cannot see anything... I see a 309 stamped on the case back, could this be it....? Can you please help, below are some pictures:
