Seiko S-6 Grease vs. Bergeon KT22
I'm reassembling my first Seiko movement, a calibre 7s36B, and I'm about to lubricate the second reduction wheel. According to Seiko's technical guide Seiko's S-6 Silicon Grease should be used. CousinsUK has it in stock (link here). Anyway, it's pretty expensive and I don't expect to service any similar Seiko movement any time soon (very educational, not for beginners, movement to service but right now I suffer from a "Seiko and Orient fatigue" ;)).
So, my question is; do you think I could use Bergeon's KT22 - Silicone Grease (which I happen to have at hand) as a good or decent replacement (link here)? If not, I'd appreciate any other recommendations!
Edited by VWatchie
I wouldn't follow the Seiko guide too closely. There's the obviously questionable suggestion that you oil the pallet pivots, and there's the use of "S-6" in parts of the train. That's a grease, and I know of no other manufacturer that call for the use of grease in any part of the train in any caliber this size. I would improvise and use HP1300 there like any other automatic device. I would however use some grease on pawl and ratchet teeth on the second reduction wheel. I can see that wearing down over time without a heavier lubricant.
We had another member recently looking for reassurance about using Seiko lubricants, but no amount of good reasoning prevented him from spending on that. Probably caused by blind faith in written material over relying on other's experience when it comes to a question asked many times on this forum alone.
Quote
I use 8301 there. A bit messy and natural based, still better than leaving it dry like the factory does.
Seiko's technical guide recommends S-6 silicon grease for the second reduction wheel and it would seem some of you would prefer a thicker oil like D5 or HP-1300 whereas @jdm and @CaptCalvin prefer a grease. According to CousinsUK 8301 contains graphite and is similar to Seiko S-4 and is the recommended grease for the first reduction wheel.
Hmm... Since S-6 is a grease I believe a grease would be the better option. So, how about some Moebius 9501 as I have it?
Apart from the grease/heavy oil aspect, silicone grease is very difficult to remove once applied.  If it migrates to other parts there could be problems in store.  I worked in the lubes industry and we avoided silicone whenever we could as we could not make other lubes on the same plant until it had been mechanically cleaned!  There are oils (not watch types) that contain silicone but these are normally for larger mechanisms.  HP1300 would be my choice, but if grease then 9501 as this is quite a soft/oily grease (silicone grease tends to be stiffer).  Just my thoughts.
2 hours ago, VWatchie said:
So perhaps Moebius 9501 or Moebius 9504 grease?
I'm not sure it's too critical. There are no wrong answers here. I used Molykote Dx as it's cheap, it works well, and  it's what I had.
Well I try to keep application of oils to pivots only as much as possible. Minimizes the risk of spreading.
Edited by CaptCalvin
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
