Chinese automatic oiler
5 minutes ago, Nucejoe said:
Once showed how he used his auto oiler, I think bergeon for about twice the price.
Not much more expensive! why go with the cheap one.
Have you tried both to make this suggestion? Or at least one?
3 minutes ago, Nucejoe said:
I think the amount of oil he put on endstone was just perfect.
With the topic now well derailed let's further entertain ourselves looking at what our Host Mark Lovick, the man than runs and pays for this forum, has to say on the subject.
Yes. This is the video that prompted me to look into getting an automatic oiler again. Several years ago I asked my mentor about automatic oilers. His opinion was that it was an unnecessary luxury. He tends to be old school and even makes his own precision oilers from sewing needles.
But recently I've been restoring pre 60's watches and they don't have shock springs. It's a real pain to lubricate such jewels.
I don't know if any of you have this problem with steel oilers, but here in Singapore, it's so humid that if I leave my oilers uncapped on my bench for a couple of days, it'll start rusting.
I might get one of these Chinese oilers as with the discounts and coupons, it comes to 1/3 the price of a Bergeon.
I understand your teacher's position, i think it's not a strictly necessary tool. What the automatic can't replace is the applicator which is a fine round pin for jewels where is difficult or not practical to separate the cap jewel, e.g. the two small diashock on Seiko, or rubbed in.
Rub-in jewels have integrated end stone, out of obsession I am always concerned if I have managed to get enough oil on its end stone, automatic oiler seem assuring to have dispensed that certain amount of oil there,  one can double the amount by pumping twice and the exactness of the amount is a nice control to have.
In a sense, same story with screw on end stones, you can just screw the end stone on and then oil. Much neater outcome since end stone plate/ holder is sure to move when you try to place it on and oil gets spread around by the old method.
I use old accupuncture needles as oiler.
I don't think you can really pump in oil in there since the air trapped in prevents that. And any oil left on the flat facing the balance is count productive. So the fine applicator is used to push some oil in the hole.  That is my understanding at least.
I got my Chinese oiler last week but haven't actually used it on a balance jewel.
I noticed that if I press the oiling pin in or pull back the on the button, oil starts to flow and continues to flow as long as the pin is depressed. i.e. the size of the oil drop is time dependent.
Is that normal? Does the bergeon work in the same manner?
No, I don't think that is normal for an automatic oiler. The whole point is to get a perfect amount of oil each time the oiler is used and that is not possible if it depends on how long you apply pressure to the button. Are you sure it is actually working like this ?
  • 4 months later...
I got a chinese oiler. Very tricky stuff this oiling. The tip is connical and it is 14/100 in diameter.  It wouldn't penetrate the hole down to the cap jewel. I MADE IT THINNER AT THE TIP BUT although it reaches now the cap jewel it does not deposit oil on it. I MADE 10 ATTEMPTS BUT IT ONLY FILLS THE CUP OF THE HOLE JEWEL.  Аll tests were on a rub-in balance bridge. I continue reflecting on the problem. Any idea is welcome.
Edited by Vladi
Also I would appreciate if someone  who has the original bergeon 1A described the shape of the tip and how much it protrudes when the slide button is at bottom dead center and at upper dead center. My goal is to clarify the general principle of action  and the capillary effects involved.
I don't use it much. But I did manage to get occasional success.
Don't fill too much oil in the reservoir, about half full is all you need. I also removed the needle and gave it a good wash in alcohol. I think it needs the mechanism to be clean and dry for air pressure to equalize between the outside atmosphere and the reservoir.
Because of its unpredictable success, I only use it for oiling escapement jewels.
  • 5 months later...
Hi all
I am looking to get an Auto Oiler but at the moment I can't justify the cost of the Bergeon ones at the moment so have been looking at alternatives and came across what look like Clones of the Bergeon tool as seen here https://www.ebay.co.uk/itm/384196684681 It looks identical to the Bergeon even down to the model number, unless they are also making them for Bergeon ;)
Anyone tried the Chinese version, how did you get on with it
The smallest size the Chinese offer is 0.8mm how does that compare to the smallest Begeon as Bergeon do not list the actual size of their models.
At £30 its till a lot of money which I don't want to spend if it does not work.
Thanks for any input on this.
Paul
I remember it has been discussed in the past. Try on Google:
site:watchrepairtalk.com "chinese oiler"
and without quotes too.
Well I bit the bullet and got one of the Chinese oilers, about £30 and took about a week to arrive, which is quicker than some UK based sellers manage.
Had a bit of a play and so far it seems to work well, depositing just the right amount of oil on the jewel, much more accurate than I was managing doing it by hand using the normal oilers.
It's quite amazing just how much this looks like the Bergeon version, even down to the model number, everything including the stand looks identical.  I wouldn't be surprised if it turned out they actually made the Bergson one for them, it's that close. Just a third of the price.
Paul
Have you tried oiling a closed shock jewel through the hole? Mine just leaves a mess and nothing get through the hole to the cap jewel.
You need to drive the oil down the hole with a pin, like the incablock gold color tool.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
