Chinese automatic oiler
5 minutes ago, Nucejoe said:
Once showed how he used his auto oiler, I think bergeon for about twice the price.
Not much more expensive! why go with the cheap one.
Have you tried both to make this suggestion? Or at least one?
3 minutes ago, Nucejoe said:
I think the amount of oil he put on endstone was just perfect.
With the topic now well derailed let's further entertain ourselves looking at what our Host Mark Lovick, the man than runs and pays for this forum, has to say on the subject.
Yes. This is the video that prompted me to look into getting an automatic oiler again. Several years ago I asked my mentor about automatic oilers. His opinion was that it was an unnecessary luxury. He tends to be old school and even makes his own precision oilers from sewing needles.
But recently I've been restoring pre 60's watches and they don't have shock springs. It's a real pain to lubricate such jewels.
I don't know if any of you have this problem with steel oilers, but here in Singapore, it's so humid that if I leave my oilers uncapped on my bench for a couple of days, it'll start rusting.
I might get one of these Chinese oilers as with the discounts and coupons, it comes to 1/3 the price of a Bergeon.
I understand your teacher's position, i think it's not a strictly necessary tool. What the automatic can't replace is the applicator which is a fine round pin for jewels where is difficult or not practical to separate the cap jewel, e.g. the two small diashock on Seiko, or rubbed in.
Rub-in jewels have integrated end stone, out of obsession I am always concerned if I have managed to get enough oil on its end stone, automatic oiler seem assuring to have dispensed that certain amount of oil there,  one can double the amount by pumping twice and the exactness of the amount is a nice control to have.
In a sense, same story with screw on end stones, you can just screw the end stone on and then oil. Much neater outcome since end stone plate/ holder is sure to move when you try to place it on and oil gets spread around by the old method.
I use old accupuncture needles as oiler.
I don't think you can really pump in oil in there since the air trapped in prevents that. And any oil left on the flat facing the balance is count productive. So the fine applicator is used to push some oil in the hole.  That is my understanding at least.
I got my Chinese oiler last week but haven't actually used it on a balance jewel.
I noticed that if I press the oiling pin in or pull back the on the button, oil starts to flow and continues to flow as long as the pin is depressed. i.e. the size of the oil drop is time dependent.
Is that normal? Does the bergeon work in the same manner?
No, I don't think that is normal for an automatic oiler. The whole point is to get a perfect amount of oil each time the oiler is used and that is not possible if it depends on how long you apply pressure to the button. Are you sure it is actually working like this ?
  • 4 months later...
I got a chinese oiler. Very tricky stuff this oiling. The tip is connical and it is 14/100 in diameter.  It wouldn't penetrate the hole down to the cap jewel. I MADE IT THINNER AT THE TIP BUT although it reaches now the cap jewel it does not deposit oil on it. I MADE 10 ATTEMPTS BUT IT ONLY FILLS THE CUP OF THE HOLE JEWEL.  Аll tests were on a rub-in balance bridge. I continue reflecting on the problem. Any idea is welcome.
Edited by Vladi
Also I would appreciate if someone  who has the original bergeon 1A described the shape of the tip and how much it protrudes when the slide button is at bottom dead center and at upper dead center. My goal is to clarify the general principle of action  and the capillary effects involved.
I don't use it much. But I did manage to get occasional success.
Don't fill too much oil in the reservoir, about half full is all you need. I also removed the needle and gave it a good wash in alcohol. I think it needs the mechanism to be clean and dry for air pressure to equalize between the outside atmosphere and the reservoir.
Because of its unpredictable success, I only use it for oiling escapement jewels.
  • 5 months later...
Hi all
I am looking to get an Auto Oiler but at the moment I can't justify the cost of the Bergeon ones at the moment so have been looking at alternatives and came across what look like Clones of the Bergeon tool as seen here https://www.ebay.co.uk/itm/384196684681 It looks identical to the Bergeon even down to the model number, unless they are also making them for Bergeon ;)
Anyone tried the Chinese version, how did you get on with it
The smallest size the Chinese offer is 0.8mm how does that compare to the smallest Begeon as Bergeon do not list the actual size of their models.
At £30 its till a lot of money which I don't want to spend if it does not work.
Thanks for any input on this.
Paul
I remember it has been discussed in the past. Try on Google:
site:watchrepairtalk.com "chinese oiler"
and without quotes too.
Well I bit the bullet and got one of the Chinese oilers, about £30 and took about a week to arrive, which is quicker than some UK based sellers manage.
Had a bit of a play and so far it seems to work well, depositing just the right amount of oil on the jewel, much more accurate than I was managing doing it by hand using the normal oilers.
It's quite amazing just how much this looks like the Bergeon version, even down to the model number, everything including the stand looks identical.  I wouldn't be surprised if it turned out they actually made the Bergson one for them, it's that close. Just a third of the price.
Paul
Have you tried oiling a closed shock jewel through the hole? Mine just leaves a mess and nothing get through the hole to the cap jewel.
You need to drive the oil down the hole with a pin, like the incablock gold color tool.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
