Timex Q Quartz
I just received my Timex Q Quartz. It is running fine but appears to have fungus on the dial. Battery hatch gasket was missing and the case gasket was damaged.
Full of lint inside. There was a whole ring of lint wound around the winding stem. Looked like a felt washer. :D
And I found another "felt washer" under the hands. Should have taken photos of it to see if it would win any prize.
In spite if all the foreign bodies inside, the watch was still keeping good time.
Can anyone identify the movement inside?
I would be grateful if someone could post the tech sheet for this movement. :thumbsu:
The movement spacer has the number M64 on it. But from Dr Ranfft's website, it looks more like a M63.
Anyway, the movement is running fine, accurate to about 3 seconds a day. So I decided to leave it alone. I only cleaned up the dial, relumed the hands and polished the case.
Had to take my Q Quartz apart to check. It stopped on my wrist 3 times today.
Found quite a few magnetic particles stuck to various parts inside the movement.
Being a quartz watch, I thought I've seen the last of my good friend - the contact spring. But lo and behold.... it's still here! :startle:
Battling several technical problems at home and at work this week. It'll be some time before I can get down to putting it back together.
Love and hate these electric q quartz watches.
When they run they usually run well if they don't my success rate at servicing is 50%.
I hate the day and date indexing springs which are really fiddly and then you have a dial with tabs to fit over them its painful!
Fitting the coil balance, near a magnet also has its moments of frustration.
I couldn't sleep thinking about this watch. So I got up at 1 am to fix it.
I agree with everything you said. There are days when it would take me almost an hour to get the gear train in. But tonight, everything went smoothly. :D
It's ticking again. Let's see if it'll behave now. :sleep:
  • 5 months later...
This watch worked fine for about 6 months then recently it stops intermittently.
I took everything apart and cleaned them again. While regulating the watch, I noticed that one end of the trimmer on the pcb was lifted. When I poked at it to investigate further, the entire trimmer fell off. There doesn't appear to be any solder on the trimmer leads or the pcb pads, just a couple of blobs what appears to be epoxy. I know this watch was manufactured inthe 70's, during the infancy of smd technology, but to expect good electrical contact with a few blobs of glue?
I'll try soldering it back tomorrow but my hands were trembling quite badly just now, due to the side effects of my 2nd dose of Covid vaccine. I had ALL the known side effects of the vaccine, headache, bodyaches, joint pain, fever, chills, tiredness...
I hope there are no permanent side effects. ?
Nice.  What did you use for lume?
Get well soon Hectorlooi.....
If you can't fix it PM me as I should have a spare circuit board.
BTW I'm looking for the date spring for few watches like these.....they always seem to be broken!
7 hours ago, HectorLooi said:
This is beginning to look like a never ending project. While checking the performance on the timegrapher, the jaws slipped and took out an hour index and the Timex logo. ?
No! Bad Luck but it should be an easy fix for someone with your skills. I have some similar clean dials for GP models if needed.
I need a battery clamp like you have.
Edited by Melt
42 minutes ago, HectorLooi said:
I made it out of copper wire in 5 minutes.
I like the battery clip too.  Timex did make these for many of the early battery ops.  I have to dig a few up to show. But in the meantime, I did work on an early big "Q" today myself.    The checked my NOS stock and found a replacement bezel and stem\crown. Looks great with the original stretch strap too.
  • Similar Content
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
