Twisted and bent hairspring
Khan
Hi guys.
Can such crooked hairssprings be rescued?
I feel the more I correct it, the more crooked it gets. I guess that I should fix the twisting first, so that its flat horizontal and then turn it into a circle? I have seen Mark's videos but this seems different.
Hi guys.
It is a very difficult job to straighten out a hairspring. I would recommend taking all the twists out first. Then I would start bending the round. Once it is flat and round, I would determine where the turn starts and make sure the angle up and then flat is correct and aligned to the stud holder on the balance cock. Then shape it to follow the regulator path.
  • Sad 1
hairspring work is a craft and trade unto itself, and a vanishing art. back in the days of old when pocketwatches were the smartphones of their day, a master would even send his hairspring work to a specialist called a "Vibrator," of all things. thats all they did for 8 hrs a day for an entire career. a very exact, and mysterious science.  just recently I had a twisted up hairspring, what I dubbed the "slinky snafu," not only was it kinked, it had twisted across itself. nope. not even close. I spent a ton of time on it, no luck. The more I tried, the worse it got. I lost that battle but will try again when the opportunity presents itself. mark made it look easy. I wish I had even come close to that. I had to replace it. good luck my friend. don't pull too much hair out...
my apologies for the terrible pun. that was awful.
On 8/5/2020 at 3:56 AM, watchweasol said:
I have done Balance springs they take a lot of time and a lot of patience, the last one took days tweaking it and then leaving it untill my mind cleared then at it again not easy for the casual repair person.
Totally agree.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
    • Sirius. Thank you for helping others with that information. This is why this forum is so good.
    • Yes watchie , the indirect center seconds wheel. Also known as a sweep wheel remover.  If you zoom in to pullers you will see one plain bent puller and the other is split to bridge over one of the spokes. Cousins have been out of them for ages , they say the manufacturer for them for bergeon is no longer in business. Another company is supposed to be stepping in whenever that might be. The new ones dont look as well made as the vintage ones, but thats standard these days. I know you prefer the old swiss tools anyway.
