  • 0
Need help getting the right mainspring winders (plus bonus question!)
Question
Hi, I'm going through the course and have disassembled a Seagull ST36 (6497), have cleaned the movement (except for the Going Mainspring/Barrel).
I need to get the correct mainspring winders for the following:
Seagul ST36 (6497 clone).
Seagull ST2100 (ETA 2836 clone).
Seiko NH35A.
Are there acceptable budget options?
Thanks.
Bonus question: I'd like to use a dial without the extended seconds pinion on the seconds wheel. What is the best way to remove this?
Link to post
3 answers to this question
  • 0
So you don't want to have any seconds hand?
If not you have to grind of the extra part of the pinion sticking out from the jewel, be sure not to take away too much since you still need it to rest in the jewel.
Link to post
  • 0
From what I have learned on this site There is always an answer,  Ali express (china)  apparently does some passable spring winders so that may be your first port of call, Cousins uk, Jules Borel, timesavers, esslinger in the USA are also material houses from where tools can be purchased.
Link to post
Answer this question...
    • Lots of parts which are in fact separate are not sold individually. Other examples are  the rotating bezel insert, or the mainspring. The latter fact is guaranteed to give an hissy fit to beginners especially. Normally that happens when special techniques or tools are needed, and chances of damage are significant In the end it simplifies the maker but increases repair cost, unless the repairman is able and willing to go the extra mile. The practice is not certainly not unique to Seiko, or for that matter, to the watch industry.
    • Be reassured, they don't bite. Not really, check below However, 320 deg. on an old movement.t is impossible for any sustained time. What can happen when swinging 160 deg sometime the Chinese machine can't read that properly, and doubles it up. It it was so easy to get maximum winding from an automatic barrel, no braking greases would be needed or sold. Anyway, and I am repeating this here for other readers, the design of any automatic watch, Seiko or other brand, is so that no rebanking will happen, even if the mainspring is wound up to maximumum theoretically possible for its geometry.
    • Unfortunately I do not have crystal lift tool. Did u used crystal lift tool to compress the crystal and fit it right into the bezel?
    • Hopefully it just need regulation, however to be diagnosed as a minimum the watch needs to placed on a timegrapher, which is also needed for a correct regulation across positions as well. In the US, 200 USD would proably be a low estimate. You have posted in the sectiond dedicated to own repairs and projects. There is a dedicated one for questions.
