Kaiser 1930s Clock Issues. Please help
ReeceJ
Hi Guys
New to clock repair do need help. As the photos show.  I have a 1930s Kaiser clock which has an issue unwinding the spring rapidly. It looks like there's an issue with the escapement. Can anyone offer advise regarding the escapement and if you can see any big issues or damage etc. Also advice on how it actually works etc.
Thanks in advance.
cheers Reece
Welcome to the forum ReeceJ.
There seems to be a couple of faults on your clock . The first thing you could do is to look if there are any pins on your fork (pin lever) , when I look at the upper picture it looks like they broken off. Next you should fix that hairspring.
After you done a bit of clock repair you could say hi to the crowd which are eager to know a little about you here.
https://www.watchrepairtalk.com/forum/23-introduce-yourself-here/
Edited by HSL
Hi and welcome to the forum Reece.  Like the others I would say thet the pallet/fork pins are broken off and the balance spring is not flat.  How did the pallet pins get broken off.  If they just sheared then check out the wheels for damaged teeth and bent pivots while its dismantled.
13 minutes ago, ReeceJ said:
Great thanks for the awesome input guys. I'll look to get what's left of the existing pins out and from reading, may try fitting with modified sewing needles. Anyone here done this before?
cheers
Have you looked into replacing the pins or the fork complete. Don't matrial houses supply new ones.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
