12 hours ago, ro63rto said:
These come up every few months in Lidl. I got mine for £12.99
Multiple Kelvin settings to suit and plenty bright enough.
That looks far better than the one I have. I don’t think mine goes up to 6500K. Mine makes no difference at all when I have the bench lamp on, not even worth switching on. It’s few years old now and the bench light is fairly new.
That is the light temperature not the intensity. 6500 is ice cold, I suggest you try 4000 natural white, it's a matter of preference after all.
8 hours ago, PeterS said:
18W sounds great, can you post a link so I know what I’m looking for? I'm sure I would find something similar in the UK.
In the electric shop ask for a LED tube of the length you want, and the two bare holders, you will need to wire one only. These items are so cheap is not worth to buy online.
  • 7 months later...
I really like that, I don't know if it was your intention or not, but I love the 'steampunk' look about it, if you could just fit a large analogue dial mounted in a brass plate to adjust the brightness it will be complete. :D
I was looking for bolts and hex nuts when i got a glimpse of the box holding those barrels and i immediately knew that this is the right thing to do. :) The barrels and knurling was all for the lookout not for practicality. I must have some rest and do something else before I go back to the lamp. More about it here: bench lamp
  • 4 months later...
3 minutes ago, wudce said:
beat me to it. yep, thats what I use too. Esslinger is a great source for stuff but save your money for the spendy stuff you WILL need in the near future. Walmart, Menards is another good one, home depot...any of the big box stores you can get a lamp for cheap. remember, get the LED stuff-they're exceptionally bright, usually have more than one setting(dimmer)and last quite awhile. oh and later on, grab yourself a small bore light, for the close-in stuff sometimes. I've seen em at auto parts stores at the checkout lane for a couple bucks. they come in handy.
Light projected on the movement only, I make me a lamp with six bulbs( projection type) and switches to trun on them in different combination. This furnishes you control over the amount of light as you need them for different tasks.
Light where the work piece isn't distracts your attention leaves you with tierd eyes.
The light you use also needs to work with the surface you are going to work on. A green surface is very good, you don't want a light that throws out heat, you need something that doesn't give off a shadow but also flexible so you can adjust it. You also need good light in the room. I have strip lighting on the ceiling and around the side of some of the walls.
My preference was a green surface and a light like this type. Found this on the internet its not my bench
For sure get a LED light so there no heat and I also like a green work mat. I have my work table set up in a very small room and in this room there also all my computer equipment and my drum kit so no room for a bigger work table. Here a shot with just the lamp on and no over head light.
I've had my eye on that microscope for parts inspection. How are you finding it?
Sent from my SM-G973F using Tapatalk
So far so good. You can take pictures and do videos with it if you have a micro sd card which I don't and you can tilt it if need be. Also the lights can be adjusted. Here a shot of a Pallet fork, I'm sure it would look better if I could take the shot with it and not my hand held camera.  Only con is it comes with only a USB cable to charge the batteries but you can use a wall charger which I happen to have.
Edited by wudce
I have a similar digital microscope, and it was possibile to display the images on my laptop or monitor via the USB cable. If that works, you should be able to save images direct to your hard-drive. The images are far better quality than those displayed on the integrated screen.
That would be right there no output to a laptop etc but not a big deal for me since this is just for inspection. The image is far better than what you see here since like I said I took the picture with a camera.
I use 2 LED lathe lights. It offers me more flexibility. I can tilt the light to get into every corner.
I can use it with the lathe, staking tool, jewelling tool... with 2 lights you can position them until you get a shadow free view. You can position them like a copy stand and get reflection free photos.
Which microscope is that? How much did you pay for it?
Would this microscope show  scratches on the face of pallet jewel or a real tiny damage on a pivot or on escape teeth?
How can good work be expected of a good horologist/ repairman if he is not equipped with optical tool to see that tiny damage?
I don't think these cheapy digital microscopes can deliver the quality we need.
I wouldn't waste money on them unless it shows me that tiny damage.
These microscopes are not like opticals, but for the price (around 30 € incl p&p) they do great job. As an amateur with a limited budget and limited work space, I'm quite pleased with it and in my opinion yes you can detect small damage. I'm sure you can work better with optical tools, of course.
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
