  • 0
WatchRepairrr
Need help for beginner
Question
13 answers to this question
  • 0
3 minutes ago, wudce said:
beat me to it. yep, thats what I use too. Esslinger is a great source for stuff but save your money for the spendy stuff you WILL need in the near future. Walmart, Menards is another good one, home depot...any of the big box stores you can get a lamp for cheap. remember, get the LED stuff-they're exceptionally bright, usually have more than one setting(dimmer)and last quite awhile. oh and later on, grab yourself a small bore light, for the close-in stuff sometimes. I've seen em at auto parts stores at the checkout lane for a couple bucks. they come in handy.
Share this post
Link to post
  • 0
Light projected on the movement only, I make me a lamp with six bulbs( projection type) and switches to trun on them in different combination. This furnishes you control over the amount of light as you need them for different tasks.
Light where the work piece isn't distracts your attention leaves you with tierd eyes.
Share this post
Link to post
  • 0
The light you use also needs to work with the surface you are going to work on. A green surface is very good, you don't want a light that throws out heat, you need something that doesn't give off a shadow but also flexible so you can adjust it. You also need good light in the room. I have strip lighting on the ceiling and around the side of some of the walls.
My preference was a green surface and a light like this type. Found this on the internet its not my bench
Share this post
Link to post
  • 0
For sure get a LED light so there no heat and I also like a green work mat. I have my work table set up in a very small room and in this room there also all my computer equipment and my drum kit so no room for a bigger work table. Here a shot with just the lamp on and no over head light.
Share this post
Link to post
  • 0
I've had my eye on that microscope for parts inspection. How are you finding it?
Sent from my SM-G973F using Tapatalk
Share this post
Link to post
  • 0
So far so good. You can take pictures and do videos with it if you have a micro sd card which I don't and you can tilt it if need be. Also the lights can be adjusted. Here a shot of a Pallet fork, I'm sure it would look better if I could take the shot with it and not my hand held camera.  Only con is it comes with only a USB cable to charge the batteries but you can use a wall charger which I happen to have.
Edited by wudce
Share this post
Link to post
  • 0
I have a similar digital microscope, and it was possibile to display the images on my laptop or monitor via the USB cable. If that works, you should be able to save images direct to your hard-drive. The images are far better quality than those displayed on the integrated screen.
Share this post
Link to post
  • 0
That would be right there no output to a laptop etc but not a big deal for me since this is just for inspection. The image is far better than what you see here since like I said I took the picture with a camera.
Share this post
Link to post
  • 0
I use 2 LED lathe lights. It offers me more flexibility. I can tilt the light to get into every corner.
I can use it with the lathe, staking tool, jewelling tool... with 2 lights you can position them until you get a shadow free view. You can position them like a copy stand and get reflection free photos.
Share this post
Link to post
Answer this question...
Loading...
