New member
owlet72
Hello and welcome to the forum , Get the best tools you can afford in order to persue your hobby, Dumont tweezers  A*F/bergeon/french pattern screwdrivers and of course some good optics, regarding a cleaning machine, not totaly necessary for the Hobbyist. Cleaning by with Benzine, Naptha, Isopropyl Alchohol  or a small ultrasonic will suffice .       enjoy
Thank you for your introduction and welcome to this friendly forum.
No not necessary but once you have used a watch cleaning machine you will see just how quick and how much better it is.
watchweasol has suggested tweezers and screwdrivers I support his advice. You will probably need a few different eye glasses for  very close up work normal work etc. of cause it will depend on your sight, do not strain your eyes,  good light is also very important and posture so get a nice comfy seat and make sure you have ample leg room. Working on carpet is not advisable as things get lost.
Hi folks, Im Paul, another new member here. I'm keenly paying attention to the advice given. Great tips on what tools to start collecting, got A*F screwdrivers on the spindle, got some locking tweezers from when i did gemmology, but I'll look for the dumonts.
I'm inspired to fix my grandfathers watch, but I'm scared to touch it as my first. So I'll need to get some tinkering watches to start. Any advice on good books to read?
Hi welcome to the forum,  A good idea not to start with the family heirloom,  Have a look on the bay for some cheap Russian and Seikos (india)  to plactice on there is plenty of data on them and they are sound and robust.  Regarding books  Henry B Fried and Donald De Carls books although quite old and probably not relavant to todays modern watches still contain a wealth of knowledge on Horology.   Our Administrator Mark Lovick has produced some videos on UTube  and are well worth the time to look at. He has also provided a paid for watch repair course on line which is available.  It depends on how far you want to go.           cheers
Great suggestions, I shall get cracking this weekend. Thanks watchweasol. Very exciting. I do worry about the condition of the dial on grandpa's watch, i think that is the only thing that can deteriorate over time. Is there any way to arrest the spread of oxidation or verdigris? At least until i am good enough to restore. It's very sad, looks like algal bloom on a pond :(
That is a fabulous document, what a remarkable collection of tips. Thank you for sharing, and thanks DrG for creating it. It's such a daunting prospect to start from scratch, but this site is a treasure trove of wisdom and friendly advice.
Hi  You can try a moist cotton bud  and only moist not wet  mild soapy water,  and remove as much as you can but be careful of the printing some will come off , A soft pencil rubber may also be used but again careful is the watch word, and try the method in an unconspicious place first.
57 minutes ago, Pjmat2 said:
Have you seen a more tragic dial?
Usually one uses a petri dish to grow fungi in.
I would recommend you sent the dial to a professional restorer. It will be a stunning old watch when finnished.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
