Advice needed
Hi fellow inmates, first I know nothing about quartz watches, but have my cousins Orient that is a "non runner" I have tried a new battery so far. I am thinking of a replacement movement ? and have tried to source one to no avail. If anyone knows where I can obtain one I would be grateful.
I'm sorry I can't help you!
Needed a going barrel for an Orient and desperately searched for one everywhere. Eventually wrote directly to Orient and beg them to help me. Their response? Never heard from them! Eventually found a compatible scrap calibre on eBay but it was long and painful process. Finding parts and replacements is sometimes so difficult it almost kills the fun and the hobby. It should be made illegal to make spare parts unavailable to the public, like it is with spare parts for cars. Anyway, good luck!
Thank you for putting me right, I didn't realise how hard it is to get parts/movements etc. I wonder if there are replacement movements from another brand ? I can't even work out the Cal, I see 5j stamped on the movement? Could that be the Cal ?
More  like 5 jewels I would think.I dont like taking apart  quartz movements  myself. Too many plastic parts to break. If it isn't dead  dead .you could try the spray  and pray method. Plastic safe electric contact cleaner. Remove the dial and hands.and GENTLY let the cleaner  run through the movement  washing out the gunk. Let  it dry THOROUGHLY  and oil. There's  a good chance it will  work.
The movement is a cal.53530. search 'Orient 53530' in ebay and with a bit of luck you will find a working watch 'cosmetically challenged' with movement that you can swap out...:)
Edited by JohnD
7 minutes ago, Johnnie said:
Hi Yankeedog, thank you very much, a good idea and well worth giving it a try. Many thanks.
It's  not working anyway..it has worked  for  me,or I would  not suggest  it.
1 minute ago, Johnnie said:
JohnD, again many thanks for the information, at least I now know what I am looking for.
Not much in ebay UK at the moment , just a few odd parts. There may be nothing wrong with the movement other than gummed up 'works', I find this a lot with 40 year old quartz watches. I do have the advantage of a Seiko Quartz tester though and can quickly confirm if the electronics are running despite no movement of the hands....
Just had a closer look at your photo of the movement and the insulator under the battery looks to be misplaced, it should be slotted over the -ve  terminal then the 'tag' on it insulates the vertical part of it and stops it touching the +ve ouside of the battery....
Edited by JohnD
Very  smoothological. Good  eye.
Hi  Johnnie  If when the insulator is re fitted it still not going   Hattori VX11  and VX51 etc depending on the ligne size of movement. Most will need the dial feet moving or removing and resort to stickers.  And possible hand sets .       Attached two docs which might be usefull if you have to on the search.    cheers
List of WATCH MOVEMENTS J Borel.pdf Watch Movement Catalog (1).pdf
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
