My watch "collection" So far. :)
Rocket
This is my personal watches. I got the as birthdays presents over the years. The blue Seiko I got from a work project as thanks you.
They were daily use and abuse. Except the Anker.  Im not in to quartz. But I will change batteries, service, and and buff them up. Not in picture. But daytime I use a Applewatch. Hopefully it will soon change to a pure mechanical watch. That I have restored my self.
The Anker is a very beloved watch. As a kid, I got it new from my father in 1978. A year later he passed away suddenly. It is totally original, plastic bracelet and all.  I pretty much never wore it, because it was too big at the time. He was a sports diver, and of coarse. He got me a divers watch. :)
I remember trying to punch a new hole, to get it to fit it to my wrist. But was still to big. And when I grew up. It wasn't cool anymore. So it is pretty much scratch free.
It has a problem that I need to look in to later, when Im much more experienced. I remember many years ago. I tried to wind it up. But something broke. And it now only moves the hands. Even in winding position. I will look in to this with great care!  I have recently searched high and low about this particular model. But came up with nothing. I find models with the same bezel, and hands. But no one with a separate second "bullseye?"  if anyone have info where to find Anker info. I would be much appreciated!
In the near future, I hope to find a cpl of pocket watches. Also find my self starring at Landeron movements. :)
Cheers!
  • Like 5
Shouldn’t have.. Bit couldn’t resist bidding..
I always wanted a pocket watch. You know classy looking. Bit “chunky” with loud and “chunky” ticking. Won this at a good price.
I have no clue what it is. Seems like a no name. But is in nice condition. Have been serviced at least a cpl of times. There is some watchmakers markings.
Include a few pictures. So Maby one of you specialists have some leads?
It has now been laying ticking on my desk for 6hrs. Seems to keep time very well. Took a look at the balance with my loupe. Someone has been adjusting it. But the hairspring doesn’t look concentric. Well, it is Maby a project for the future. I’m happy just having it, ticking on the desk!
  • 5 months later...
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
