Advice on number of pinion leaves
Hi guys. I’m trying to think this through. I’m restoring a vintage IWC. It has a tiny power gauge works which is hard to describe, but, long story short, two tiny identically sized pinions have broken against each other. Replacements aren’t available. I don’t have the right tools to cut pinions yet. But in my scrap I’ve found a couple I can use that are the exact same diameter. Only difference, they have 10 leaves rather than 12 as the originals have. Is there going to be any disadvantage to swapping them out to 10 leaf pinions if the diameters are the same and they mesh okay? What dictates the decision to make a pinion a certain number of leaves? Is it just the size of the pinion and the ease of cutting them?
A 10 leaf pinion the same diameter as a 12 leaf pinion means they are different modules. The 12 is a smaller module.
You're saying the two 12 leaf pinions were meshing with each other? That's odd, was this part of the differential? It would be lucky if two 12 leaf pinions had the same center distance as 10 leaf even if they are the same diameter, it could be though, or close enough to still work. The 12 leaf pinions would be weaker than 10 leaf for the same diameter.
If either or both pinions are mounted to a wheel as well no way it will work, as the gear ratio will be changed. If they are just transmitting motion from another gear, through each other, to another gear, the ratio won't change.
A pic or two or three would help.
Thanks. This is probably the clearest thing to show what’s happening. I have marked both points where there are broken teeth. Both wheels are 1.39 with 12 leaves. And I propose replacing with wheels 1.39 with 10 teeth.
Just to clarify, on the right, I’m pointing at the wheel underneath that is a bit hidden in this picture.
Edited by margolisd
Bear in mind though that a pinion is usually designed to mesh with a gear of several to 7,8, or more times its number of teeth. For pinions this small to mesh together the profiles are quite modified from "normal". Even so, this is a low power situation so things are more forgiving.
    • In the meantime whilst awaiting a better plan, please drop me a quick hello on my email.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
