My Watches (So Far!!!)
vaguras
Hello guys,
after being introduced myself, I would like to share with you my watch collection so far:
To begin with, my everyday watch a Swiss Davosa (model insight - discontinued) with the robust ETA 2824-2:
An older automatic Citizen watch with a 6001 caliber (from 1976 - year of my birth as well). I found it in a drawer of a retired old watch repairer non working and managed to give its life back!
Next, goes a Citizen eco-drive the popular nighthawk model, a gift from my wife some years ago:
A classic new series (from 2010) SEIKO 5 automatic, bought second hand from fleamarket as NOS only 40 Euros :
An old SEIKO 6319 with the TV style case, a gift from an old friend, non working at the moment since the balance spring is torn!
Another SEIKO (what else haha), a hand wind one, Skyliner from 1967, repaired by me after a serious drop of my friend's father, who wore it while he was building a house from scratch. Fortunately only the pallet fork was broken and the acrylic crystal:
An automatic YEMA sous marine, with a FE (Franche Ebauche) 4611A bought lat year as NOS for 30 Euros:
Last but not least an old classic Longines 23Z from 1954 bought recently and trying to repair (needs a new mainspring as the old one is set and a new setting lever screw):
That's all folks!!!
Photos of the movements as promised!!
First the old citizen of 1976 (cal. 6001):
The Davosa with the ETA 2824-2 (nothing fancy here):
The Longines 23Z from 1954 (notice how the bad setting lever screw has damaged the barrel plate!)
My regular seiko 7s26:
The old SEIKO 6319 with the missing balance (fortunately I have found a replacement!):
The handwind SEIKO Skyliner of 1967:
Finally the YEMA with the FE 4611A:
I apologize for the not so good  quality of the photos, but I do not have a macro lens on my camera yet (an olympus E-PM1-mini mirrorless).
Cheers
Evan
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
