ETA Part Number System?
Hoe
Hi there
A rookie question:
I am working on the two vintage ETA movements 2783 and 2873 and will need spare parts for the automatic winding assemblies. While searching for these parts I came across obviously different ones which have the same part number.
Furthermore, some ETA parts are interchangeable between ETA movements.
How do I determine which part number I really need, how does ETA’s part number system work?
So far I am going for photos rather than numbers when looking for parts on Ebay.
Best wishes
a problem with this particular numbering system is that the numbers represent a part. Such as a stem is referred to part number 401. But part 401 without the movement number could refer to literally hundreds of different stems. So it's kind of a two-part system the number as opposed to the word stem bike 401 and then the movement number. Otherwise ordering a 401 all by itself it isn't going to fit.
helpful when looking for parts is the third link where you can see the differences of the watches you're looking for they appear to be in the same family. Then the first in the second plank are the parts. If you click on the part number in each of the listings it give you the cross reference the parts.
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=ETA_2773
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=ETA_2783
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&ETA_2783
To get which parts are interchangeble between the different caliber would be a mamuth book.
So insted one can buy access to an database provided by BestFit.
Here you can see the actual part number and which calibers share this part.
Access to the database is sold by Esslinger
https://www.esslinger.com/matsys-online-from-bestfit-lifetime-membership-watch-parts-lookup-software/
This is the Caliber Search
And the Interchangable list
13 minutes ago, Nucejoe said:
Dose this database or any other, also provide tech specification for parts, like CGS for HS?
No unfortunately not, to get the CGS numbers one still have to meassure the hairspring or use a bunch of old lists.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
