New Guy Intro
Hi everyone, new guy here.
Long time fan of all watches; I wear one everyday. I just bought my first Omega and plan on doing a little disassembly and reassembly with some cleaning along the way. It's a 1970 Seamaster Deville Cal 630 (manual wind). Crossing my fingers nothing goes wrong, but that's what you guys are for, right? :biggrin:
    • Before putting it back in the case I would fit the hands and use a pin vice on the stem to make sure the hands were in line.
