Any Citizen experts around?
Hi, Just bought this Citizen watch, the first Citizen I have ever owned. Just wondered if anyone knew anything about it. Never seen anything quite like the dial, looks like hammerite paint. Code on the back shows 7220. Watch is running at 21600 bph. Not opened it yet, what might I find inside?23b6154914b012a202bf6e4815eb6c15.jpg6a9d1a3870ebd26e607334cb40bfb67b.jpg
Sent from my Moto G (5) Plus using Tapatalk
20 minutes ago, steve1811uk said:
Fantastic, any idea how to source a replacement acrylic crystal as the original is too far gone?
There is no secret place for parts, we all search the Internet just like anyone can.
You can also measure and get a generic plastic or mineral glass crystal.
Edited by jdm
I mean, for Seiko I would search the case code on Jules Borel and find out the part code for the crystal. Is there a similar way to that for Citizen parts?
Not that I am aware, Citizen has always been behind Seiko in terms of post-sales support. BTW the same parts search is also possible on Cousins UK, Boley.de, and Seiko Australia.
From what I see you acrilic crystal is still repairable to a good extent, personally I would look for a solid mineral glass replacement.
Thewatchsite.com specialize in Japanese watches only, you can try searching or asking there.
Edited by jdm
Glass looks you might get by with a polish.
Forgot to mention that escape has shock protection too with real little lyre springs, be carful with them.
Winder module is incorporated in gear bridge,  don't know what oil is to be used.
A datasheet be nice.
Good luck
Hi  unable to get a de code of the case numbers when you open up the watch can you post the calibre number please.  there are numbers on the dial under the no 6 marker can you also post theseif legible then we may be able to get a tech sheet,  Thanks.
Thanks, I will open it up tomorrow and also post the numbers off the dial.
7220 is a nice movement.. it has a full bridge but at least the automatic bits have their own bridge. The click is a bit difficult to spot. Once you remove the automatic reversing gears you will spot the tail. If you still cant spot it wind it a bit and you will see the click move.
Later 8220 had everything under a single bridge which is more fun...
Anilv
I found this great resource for finding case part numbers.
Nos Crystal part numbers, gasket part numbers. Etc.
https://www.boley.de/en/case-parts/citizen
Not sure if it will be a big help because it’s not comprehensive.
Here’s a link to info on movements too.
https://www.vintagewatchesspare.com/watch-parts-branded/citizen-calibre-movement-and-spares/
In the mean time check out this serial number decoder.
Might help.
Citizen
Citizen serial number decoder. Date a Citizen watch by serial number and case markings
If you can take a picture of the tiny writing just below 6 o-clock it will usually have the movement number.
Might help.
Citizen
Hi, please see some pics attached. Dial says JAPAN 6501 - 653316 KA. Not what we were expecting I think. Pretty sure the calibre reads 6501.de83a7d5cd29ec1acec283b80c27e90e.jpg390ea7bc388a0aa0a1a7ed6be3c45a7b.jpg52982df5f993638b22d64a4c50b15f12.jpg5a36f2404831bf9c73f4a468fe8e8b0c.jpg
I think this rotor has been scavenged off of 6001 which came in 17 & 21  jewels versons. Several parts are interchangable between the two. Not the caliber I spoke of.
This Calib 6501 is 21 jeweler.
I will be sure to count them when I strip it down. I think you could be right about the rotor.
$24.75 + $13 int.l sh. + UK VAT and fees.
Watch is worth, perhaps, the same. Worth to purchase, when generic or polishing are valid alternatives?
Probably not. In fact I found an equivalent on Cousins for approx £8. Original glass is too far gone has cracks on the edge and a big deep chip out of the front where it says Automatic.057ae9914a3fd9f5cadc5ab36f94a64f.jpg
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
    • I would like to see the movement. The watch is the movement. Anyone can print a name on a dial and sell it as "the maker".
    • Thanks for your answers! There seems to be a contradiction between these two answers, so perhaps I need to clarify. The flat and convex jewels look identical on the side facing away from the pivot shoulder. That is, there is an oil reservoir. I don't know if that changes anything but I thought it was safest to clarify since I didn't include a picture of the jewels from the opposite side.
