Cannon Pinion Tool Help
Hello!
I recently purchased the very useless Bergeon cannon pinion removal tool! yay. I was unaware at how pointless it is at the time of purchase
I decided to take it apart and the parts flew everywhere and now I'm struggling to reassemble it correctly. I think I may have lost a part or I'm missing something when putting it together because it doesn't work.
Could someone shed some light on this for me please :)
You're welcomed. I bought an equally useless vintage one.  Some of our members suggest putting a sheet of plastic or foil over the cannon pinion to get a better grip. I've not tried it.
I'm actually in the process of shaving down the sides of the collet so that the jaws can close down further. I'll post an update if it works. If not I'll be machining a new collet from scratch.
This is the reason I tried to dismantle it, I'm hoping to file it down.
Any chance you could give me the diameter of the ball bearing?..I've scoured the workshop and it's long gone.
Have you tried filing the jaws yet?
I got mine to be able to grip a 0.9mm wire. I could probably get it down to 0.8mm.
If you look at the photo of my puller, it has an extra pin and spring. I think it would work even without this extra pin.
Have you tried filing the jaws yet? I got mine to be able to grip a 0.9mm wire. I could probably get it down to 0.8mm.
I don't have a file thin enough to get in there unfortunately [emoji17]
Sent from my SM-G973F using Tapatalk
Just now, ThrobinsonCrusoe said:
You can do things like that sliding emery cloth or or emery paper over the blade of a feeler gauge.
2 minutes ago, ThrobinsonCrusoe said:
Thanks for the tip, this worked perfectly!
You're very welcome and to provide feedback consider using the like or thanks button, or the upvote and resolved mark in the watch repair section only.
I wonder if Bergeon was afraid of jaws breaking and made everything thicker at the expense of grip size? The collet in the first pic is quite different from Hector's above, and here you can see mine; the slits are quite big, and the jaws are shaped down to a sort of point. I have two and both will grip a 0.5mm screwdriver blade very well, both are at least 40 years old and neither are broken. Someone could make replacement collets and make a bit of cash maybe selling to those who can only find the crappy Bergeon version!
The new collet is actually very fragile, your old one looks much more robust. Mine actually cracked whilst I was filing it as it's wafer thin at the top, and the whole thing distorts very easily.
I think Bergeon are just producing a cheaper tool now but still charging a premium.
I have just purchased a new cannon pinion tool from Cousins. Tried using it on a ladies pocket watch movement and again same as you guys its too big. I will need to get a collet with a smaller hole or grind down the slots so it will close about the cannon pinion. At £59 it an expensive tool that is not much use as it is.
Is there a smaller collet that is available. I seem to remember Mark having this trouble in a previous post and I cannot remember his solution.
I filed down the gaps between the collet teeth with emery cloth. You have to be careful though at it's quite fragile.
I would have returned it if I hadn't lost the ball baring, so be careful when taking it apart.
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
    • Why just the bottom mike ? Is it worth polishing the whole arm ?
    • The one thing I took time over was to round and polish the curves at the bottom of the jumper arm. The slightest mark (left over from cutting of filing) acts as a stress raiser, just where you don't need it.
    • I printed the base and it is a bit too large to fit on the base of the hand setter. The ring bumps into the column so it is unable to full seat on the central ring. I'm going to try removing some of the materal and see if I can't get it to go down.
