Measuring Small Hand Gauges?
dpn
Hello everyone,
I continue to be very appreciative of the great advice I've received so far from this forum on a variety of topics.
Here's another hands question:
The Bergeon 30464 Hand Gauge Watchmakers Tool seems like a great tool for quickly measuring and categorizing hand gauges. Its smallest measurement is 0.30 mm, however.
How does one measure smaller second hand gauges? The best thing I can think of would be to use a micrometer on the hand pinions, but given the small difference between, say, a 0.27mm gauge and a 0.25 gauge, there seems to be a lot of room for error with a micrometer.
Thanks, as always, for any suggestions!
-- Dan
I use plug gages, which are in 0.01mm increments, but they are expensive. If you need to measure the hole in the hand and can't measure the pivot (and a micrometer will easily differentiate between 0.25 and 0.27mm, you can easily see a difference of 0.005mm), you can use a small broach. Slide the hand on until it stops, and measure there. There's a little interpolation to do, but you will be very close.
Thank you all for the great info! I really appreciate it. Sorry if these questions are stupid -- I like to think things out and talk them out to make sure I understand the correct approach to use on a given problem. I have very little hands on technical experience, and so things that may be obvious or intuitive to an experienced horologist baffle me without additional explanation.
If anyone is curious, the reason I'm asking this question is because I'm starting the process of learning how to heat blue hands. It turns out that plain steel wristwatch hands are very difficult to obtain cheaply, but there is a near limitless supply of old steel pocketwatch hands to practice with. As I practice with these, it'd be fun to measure them and see if I can assemble matching sets in dimensions suitable for use on modern wristwatch movements.
Edited by dpn
5 minutes ago, saswatch88 said:
When in doubt always go .01 smaller. You can always broch from there.
Thanks for the info @saswatch88. Would you explain what you mean by this -- stretching out the small tube on the hand?
Forgive me if this is a stupid question; I'm a complete newbie, and basic tools and techniques are unfamiliar to me.
I've ordered a Bergeon 30464 and a quality digital caliper, so I should be squared away for measurement.
I will be buying a mishmash of old pocket watch hands, as they're the most cost-effective way of obtaining steel hands for bluing practice. I plan on measuring those hands to see whether I can find any matching sets that fit currently-available wristwatch movements, both in diameter and length. If it's possible to expand or contract a hand diameter using affordable tools, I'll be ecstatic.
All the best,
Dan
Thanks for the info [mention=5720]saswatch88[/mention]. Would you explain what you mean by this -- stretching out the small tube on the hand?
All the best,
Dan
Bergeon makes sets of cutting broaches. They are 5 sets for different size ranges. They are expensive but cheap broaches dont work well. Look for a used vintage assortment. A hand holder is needed as well. The broaches will cut some of the metal off inside of the tube expanding it. Just be careful when using them I usually only do maybe one or two twists and rechecking fitment. You can very easily cut too much off.9ecc58eef379eecd18a34be6b4621d3e.jpg
@saswatch88
Thank you so much for that great explanation, those photos, and those tips. This is super cool. I'll definitely research this more, now that I know what the correct terminology and tools are. I'm in your debt.
Is there a method or tool for doing the opposite -- reducing the tube diameter? I imagine that some sort of very precise and controlled crimping of the tube would work, but I also imagine that attempting to crimp a small seconds tube down by, say, 0.02 mm with a set of tweezers would be disastrous.
There would also be hand height concerns, of course, but I'm just thinking about whether a hand tube could be reduced to fit on a smaller pinion. Maybe that's the wrong approach too -- maybe its easier to try to increase the diameter of a pinion to fit a specific diameter hand?
Thank you in advance for your continued patience here.
[mention=5720]saswatch88[/mention]  Thank you so much for that great explanation, those photos, and those tips. This is super cool. I'll definitely research this more, now that I know what the correct terminology and tools are. I'm in your debt.
some people use a cannon pinion tightener or nail clippers to crimp a Sweep seconds tube, It can’t be disastrous if you don’t know how much force to use. You can very easily just break the tube right off or over crimp it. tweezers has never worked for me. Personally I would not suggest any of these methods unless you are a seasoned watchmaker. I would just invest in some cutting broaches and a hand holder. I find that vintage sets work very well they do not make the steel like they used to. I bought a set from Esslinger for about $25 and they suck. For the same price you can get yourself a vintage set. And the hand holder is about 10 to 15 bucks.
No the adjustment must be done at the hand not the Pinion. As far as height goes that would mean staking on a new tube and that Requires a much higher level of experience. Even I can’t really do it it’s very difficult. You can shorten the tube just know that you are going to cramp the end when you cut it or file it down. And then you’ll need to use rounding broches to round it back out without removing any metal and widening the inside diameter of the tube.
 Keep that in mind that there are two types of broaches: cutting broaches and rounding/smoothing broaches. Smoothing is better used with chronograph hands after cutting, Pivot whole shaping and cleaning.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from .
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
