Hi All,
Newbie here and I posted this question on someone else's thread in this forum and am not sure if I could do that so I've started a new discussion. Admins please delete if I did something wrong here.
My local thrift shop has this vintage used Boley staking set. Photos below. Do you think it's worth £95 / USD$120? Any advice is appreciated. Cheers.
Mo
Share this post
Link to post
There looks to be many missing stakes and plugs. New stakes/plugs can be bought from good suppliers. Have a good look at what you might buy, Do the stakes line up with the holes in the bass, make sure there not blocked, the same goes for the stakes. Looks like it all needs a good clean, this can be done and it should then look fine. You can also find second hand stakes on ebay. The price is fair. Just make sure it all works and moves free.
Share this post
Link to post
Thanks for the advice. I will check it out.
Share this post
Link to post
Hi OH, I can think of trying each stake with a right size staff to see if things line up with the holes in the base. How else can we check for alignments.
Thanks in advance.
Share this post
Link to post
Make sure this part (red arrow) isn’t damaged and can lock and be freed. Some types cannot be moved so check for damage. You need to have the most pointed stake and see it it lines up center to the holes (black arrow) make sure none of the holes are damaged and not blocked. The black arrow part must be able to be un-locked and locked. All punches should be able to fit into the stand with ease. Keeping the stakes in good order and the plugs will also help in the work you will undertake when using this type of tool. It is quite easy to clean the stakes/plugs with very emery cloth or the sticks, if you have a lathe it’s even better. Don’t forget this type of tool is used a lot for watch work such as b/staffs, jeweling and riveting just to name a few. Yes if you do not have a jeweling tool but you have the right punches with a stacking tool you can use it for that. The main thing is make sure things line up.
Share this post
Link to post
Loading...
  • Similar Content
    • By matabog
      Hello!
      I just bought a Boley Staking/Jeweling tool and it's missing some punches.
      Do you know where I could buy some old/original Boley 4.7mm punches?
      Thank you!
    • Today I found out the MOERIS is a perfect counterweight on the arm when removing the balance from a dodgy AS970 balance staff. It is a UNITAS 6498 Pocket watch conversersion which will give you the perfect swagg when walking the stripp .
    • Wish I saw this post ten minutes ago, yep you guessed it, I’ve got a damaged main hand now, oh well live and learn as they say
    • Just to avoid making too many new topics with the same subject I will post these PDF:s in this old thread. Since flashplayer is obselete due to security lacks and not every one wants to activate it I have made some PDF:s with two of the most popular movements. This version uses a normal PDF format which you can print out and make notes in while servicing the movement, you can brows them offline while lapping sun. ETA 7750 Chronograph. ETA 7750 Service Notes.pdf  ETA 6497  SwissLab_6497 Service Notes.pdf
    • Thanks for the input Marc. The Bulova was the one that had me interested. As you sa,y at $4.75 each it would perhaps have been worth a gamble -  even to break and flip the unwanted ones to pay for the keepers.
    • Here’s some shots of the movement, it’s all back together at the moment and running strong, only lost 3 mins in 12 hours so I’m happy with that, even with that canon pinion, which I shall find a replacement for. I had another post a while back asking for information on the “ climax trip action” a few that answered said it was to do with the case but I’m not sure.  If you look at the top plate there is a wheel mounted on a yoke by two screws, one screw is fixed the other allows the yoke to move by a few mm via an elongated screw hole. you will notice a silver spring bar screwed to the plate which in turn locates under the wheel in a groove, of which there are two, not dissimilar to a setting lever. Now all I can see is that the wheel provides an interface for the barrel and then to pass the power to the train, I have no idea why it should be allowed to move or why, I can only assume that this piece of the movement is the “climax trip action” as I have never seen it on another movement. IMG_7837.MOV
