Watch Hand Metal?
dpn
So, I'm looking for an inexpensive supply of steel hands to practice heat bluing with.
Looking at esslinger.com, there are lots of "silver" hands available for a reasonable price. E.g.: 114 Piece White Multi-Style Watch Hands, White Dauphine Style Hour and Minute Hands, etc.
There are also, of course, a myriad of cheap silver Chinese hands available on eBay.
Does anyone know what metal inexpensive "silver" hands are typically made out of? I'm very, very new to this, and honestly don't know whether hands are typically steel, anodized aluminum, or whatever ...
Thanks in advance for any tips and advice!
Steel is what you want. Preferably stainless. Get a magnet- good quality 304, 306, 316 stainless alloy will be non magnetic. Try ofrei and kas-ker. otherwise vintage NOS is always good but like we talked about-can get spendy.
Otherwise some can be cheap tin or aluminium. Even plastic.
Stainless steel won't blue; I don't know of any watch hands being made of it either.
If the supplier doesn't state or know the material check them with a magnet. Hands can be almost any material from gold to plastic but brass and steel are the most common.
Yeah, they're out there. All modern day stuff. Micro brands.   Depending what grade and carbon content they contain  they will turn color tho. Manufcrs. don't list the grades tho lol. Just keep my trusty magnet handy. melted a plastic set once..
I've got my propane torch, my IR thermometer, my brass scarf, my brass heating box, and my polishing stuff all either here or on the way.
I honestly didn't think that finding steel hands was going to be the hard part! *grin*
I can practice a lot with screws and old blued hands, but if I want to actually make usable hands I'm going to need to figure out a supplier.
Interestingly, Esslinger has been super quick to reply to my parts inquiries. My inquiry about what makes up their "silver" hands has been met with silence, so I agree they're likely to be some kind of mystery anodized or coated base metal.
This has been, and will continue to be, a fascinating exercise. I'm going to be cross-posting on the NAWCC forums, since there's a lot of good heat-bluing info there. Maybe someone will have a good supplier they'll be willing to share.
The better the quality of the steel and with practice the better the bluing will be, you should have an even blue colour all the same. I always quenched clock hands and screws in oil, it would give a shine look and not a dull finish.
Where did you find the swarf and heat tray?
Do you every get the black tar-like crud on them when you do this? Ever had and luck with just air cool down?
If its screws after they have be cleaned and polished, I would put them in an old watch cleaning machine to make sure all dirt got completely removed, crud can be caused by bluing something that still has dirt or grease on it. Hands would be washed in soft soap and warm water and dried in a lint free cloth before bluing.
    • glad it worked out, those ESA movements are obsolete but new old stock is still out there, now that you know the make/model you could also do a cross reference to see if something more current would line up with the dial feet and hands...for future use if needed 👍
    • I wish they would have done so in this case. The whole story went like this: I sent my speedmaster to an omega service center about 10 years ago (at that point of time I haven't even started watchmaking). After the watch came back to me it had only about 6 months wristtime until january 2024 (not fair for this nice watch but the other pieces of my collection want wristtime too 🙂). So my conclusion is that the barrel was already faulty when it came back from service, can't imagine that amount of wear in 6 months wristtime. In january 2024 the performance on the wrist was quite bad, so I decided to have a look by myself. I have to admit that I didn't check the barrel close enough as I thought it must be ok, couldn't have issues after official omega service. That was a mistake, I will learn from that. Follow the golden rule: Nothing is certain except death and taxes.
    • I am same as you oldhippy I won’t touch anything with a battery, I keep getting requests to but I just say I only do mechanical clocks, there are quite a few errors & omissions with the repair guide have a look at this. https://mb.nawcc.org/wiki/Encyclopedia-Subjects/Torsion-Clocks/Book:Horolovar-400-Day-Clock-Repair-Guide-10th-Edition-Errors-and-Updates
    • Nice experiment. As it will be no problem, please put a twice less mass (half of the two penies) and read the amplitude, will be interesting. I mean to determine what is the relation torque/amplitude.
    • parts touching that aren't supposed to touch definitely would cause an issue. there not supposed to be touching there supposed to be independent which means that @VWatchie is correct that the ratchet wheel has no effect on performance. so if the ratchet wheel in your particular case is touching that is definitely going to be an issue and needs to be addressed. did you know that the Swatch group service centers do not change mainsprings? Swatch group service centers have an infinite supply of spare parts so they just change the mainspring barrel the whole thing. Plus anything else the watchmaker doesn't like just gets replaced like anything related to the escapement they just replace the components because they can.
