Time To Wind Down.
Joeydwachmaker,
The big thing in the USA at the moment is southern moonshine. It commands extremely high prices and tastes like lighter fluid. A huge order for Tim Smith Moonshine was placed by a European distributor. Once the customers tasted it they cancelled the order. I wonder if it would work in an ultrasonic cleaner to clean watch parts.
david
Mark,
With all of the wonderful available English draft brew like Thigstons Old Pecular, why on earth are you drinking beer from a bottle?
david
Only 5 choices in my local 7/11 if memory serves. Chang, Leo, Heineken, San Miguel Light and Singha.
Certainly no British gourmet beers to be had here in Thailand :P
Where are you staying, in the sticks? [emoji15]
By Privy Council's order, any 7-11 must also carry Cheers (try the new riceberry) Carlsberg, Bud, Asahi as a very minimum. I've also seen Lao which is pretty good. For more imports go to Big C. In a pinch I recommend Singha over Chang, much less hangover from it.
I mentioned 5 as far as I could remember - I don't have a forensic knowledge of every beer stocked. The point was that there is no English (or British for that matter) draft beers available in my local 7/11
I like Chang ;)
I prefer the taste over singha.
From my non-British taste position, that's actually a plus [emoji3]
Lol. I do miss that beer in my OP. Sold in Morrisons. They have a nice selection.
I most likely won't be in England until September so it's Chang until then. I do miss my Kronenberg :(
Great stuff guys.  Just been to my annual pilgrimage to our local CAMRA real ale beer-fest. You get a free pint glass so the cupboard is now getting near full (28 so far).   Link below gives list of all ales etc.  Never ever had a bad head the day after as no 'chemicals' in the real ale.  Now started doing some nice gins but not tempted to mix, hangover assured !!
http://www.bentnbongs.com/Home.asp
Hello, just read the post from Canthus, I am also a CAMRA member and look forward to April when I think the next festival is in Newcastle. However, I only get a free half pint glass at the festival !!! This is patently unfair.
Cheers
Vic
It looks like single malt Scotch wins the day.
david
Nice Rob! We can't get that brand here in the US but my "daily driver" is a Macallan 12 and it work up from there. Also in the US there is a boom of "micro distilleries" that produce some very nice bourbons
  • 1 year later...
that gets my vote, I always buy single malts, enjoying distinct and widely vary tastes......but as my Grandmother was fond of saying "there's no such thing as a bad Scotch"
  • 5 months later...
    • Showing state of hairspring on receipt, backplate & 'dished' wheel.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?       Have you seen this video, he shows how to determine where the indents go ?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
