Time To Wind Down.
Nip over with a pint, Mark - the door's open. I've got some malts to share - Old Pulteney, Dalwhinnie...
I'm there in my mind Will :)
That's s a new one on me Mark, go and enjoy, you deserve it. :)
Drambuie for me later! :) :) :)
Found it in Morrisson's a while back - it's an extremely pleasant ale.
Good for you Morton. Nothing like a cold one after a day on the bench
I've been working on my workshop today, now off to the local Indian for a curry. They do a great beer called Bangla. Really looking forward to it.
No Bob. You are the one who is spoilt :)
The best thing I brought back from Florida a few years ago was a big bottle of southern comfort special reserve.
Man that was good stuff. Can't get it over here - I really considered another trip over to get a bottle :D
    • Snap! I recently finished my Gruen 510 movement - though the case for mine is in a rather sad state; I'm going to try re-plating it (in nickel, it's not a gold one).   Re. the screws, I got a few of the one gram mixed batches from ebay. I've only needed a couple of screws for things so far, both rare, minuscule types - but both in the mix, after enough time sorting through them! The ones such as normal bridge screws are quite common in those lots.
