Time To Wind Down.
Hi all you whisky fans there is a shop in Braemar who's stock is wall to wall whiskey you name it has it   come to Bonnie Scotland and stand out side and drool. The whisky trail is well worth the time and effort.  That's the tourist jargon finished..  I like the Glenfiddich  nice  or even the Irish Black Bush well worth it  I must confess I do like good Lager or Cider from Somerset/Devon smoooooooth
Ahh yes, went to Glenfiddich Oct 2018 and stopped by Tullamore in Ireland on the same holiday. I suppose I could put watches on bottles, so stay tuned. If I had my choice the Glenfiddich 18 yr would win most arguments, just can't justify the cost, Yet!
IMG_20181010_070920.thumb.jpg.06c5767a5e0dacad98a05d2e663d795e.jpgDSCF1172.thumb.JPG.37b6cab9c70886f89f13b917b10ef032.JPGWaiting to choose the right Japanese Single malt, Yamazki just might work.
  • 4 weeks later...
  • 2 months later...
  • 4 weeks later...
  • 2 months later...
    • Hi! I am in the process of restoring a rado captain cook mkII. I want to remove the rotor, but I am not sure how to and need some help. As you can hopefully see on the photo there are 2 screws. The left one has two positions, the right one looks like a regular screw. I have tried turning the right one, but it does not give even after using more force than I would expect. Anyone know the function of the left screw with the two positions and how to remove the rotor? Thanks!!
