Lubricant for small movement
Hi everyone. I've been fiddling with several small movement. φ15~20mm The puzzle is such I always use HP1300 to oil the second and the third wheel. Sometimes I thought HP1300 maybe too thick for those slow movements. They have lower friction and smaller pivots. I already swap 9010 to oil the third wheel. What if I use 9010 to oil the second wheel as well. Will I gain or lose performence? Thank you!
I think the lubrication scheme would be almost the same down to a certain size, I seldom work on watches smaller than 7 ¾´´´ nowadays and in that size I use the same lubricats as I would on a regular 11 l½ ‴.
Just so one get a sense of size difference I took a pic. A 2824-2 vs 2671
So 2824-2 tech sheet with lubrication recomendations
https://shopb2b.eta.ch/technical_documents/index/pdf/id/1883/
And the 2671 tech sheet.
https://shopb2b.eta.ch/technical_documents/index/pdf/id/1893/
Edited by HSL
Swinglish
3 hours ago, EatPeach said:
I don't know. I don't have 9020. But what I'm thinking is HP500 and something like that. Honestly I don't know much about lubricant
most common choice for lubrication is Moebius which can be found at the link below. They even have a lubrication chart you can download to add to the confusion and a lot of tech sheets where you get some of the specifications.. iin the absence of any real specifications usually what everyone goes by is viscosity.. Lighter oils for fast moving parts heavier oils for slow moving parts..
typically I work on pocket watches this means the lightest oil on my bench is 9020  I use it almost everything except the really heavy stuff like center wheel HP 1300..
http://www.moebius-lubricants.ch/en
BHI The Practical Lubrication of Clocks and Watches Version 2008.0.pdf
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
