Mainspring acting weird!
Hey guys. One of my non-automatic mainspring is acting weird in the barrel. It's hard to describe but the mainspring wont stop and keep winding and flexing inside the barrel.
Here's a demonstration.
So after the mainspring crosses the line where it should stop normally, it curl to one side of the barrel and keep winding.
What happened? How can I fix this one?
Thank you!
Edited by EatPeach
Just now, eccentric59 said:
Sounds like the spring was over-wound and the bridle was either bent, broken or fatigued. Have you taken the spring out and inspected the end closely? It might be time for a new mainspring.
Thank you, I'll take that out and chek it tomorrow morning. Is this a common issue? I just can't come out any reason how the ms is bent.
I would expect over-winding a manual watch is fairly common, but what happens then would depend on how the mainspring is secured in the barrel. There are many different types. I'm guessing that you have the Swiss tongue end, which looks like, when wound too tightly, might bend and deflect the spring as you describe. A different style might simply break under those conditions.
yeah it's a regular swiss end. So if the bridle is bent, can I manipulate it back, just like what we do to the hairspring?
Yes it can happen with brand new, roundel-contained mainspring. The end needs to be bent just so slightly to engage the machining in barrel wall.
I'm not sure if there is a way to find out before one closes the lid on it but certainly that's is on my due diligent list when working on the the next hand wound watch,
Maybe. If it's a relatively fresh bend with no damage to the steel then you should be able to adjust it. But, if there are any signs of fatigue, then it's going to break on you sooner than later. Better to replace it now that you have it apart, IMHO.
image.thumb.png.2b0b2991777d7349691986466d16760f.pngimage.thumb.png.6903c958ed401e45634caee808be3306.pngimage.thumb.png.997cae9f96564bb7b17af50a7c1cd640.pngimage.thumb.png.2b0b2991777d7349691986466d16760f.png
looks pretty normal to me. Is it bent?
Looks okay to me. I might think it should follow the contour of the barrel a little closer, but then not too much or it could slip off the stop. But, that's not your problem, right?  You're saying that when fully wound the back of the spring lifts off the barrel.
Yeah it does not slip actually. Is just the bridle and the end of the spring will not cling the barrel wall and keep wind up
The reverse curve of the spring is supposed to keep the tongue pressed against the barrel. Perhaps the spring is simply too weak? (Just guessin' here).
that might be possible. Let me change a new one and check the performence. I dont see any significant issue with this mainspring, I dont even know how to start it. So best to change a new one
it seems like the spring is way to weak....a spring with correct strength for the barrel should be sitting a lot closer to the barrel wall, and the bridal should have more curvature to it which also not helping with the situation, so i would get a pair of round shank beading pliers and curve the bridle a bit more then see if it slips.
Edited by saswatch88
    • Would be interesting to see it 🙂
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
